Floyd Brothers 70 Challenger
As at a couple of days ago, things have been going a lot better, now that the brunt of the de-grotting has been done.
Outer roof rails are now replaced, leading has been removed from the joints, 'oles made good and everything is being taken back, prepped properly and treated. Next is to drop the roof back on to position the drip rails and then get them fitted.
Some more pictures of it starting to look better.
1. Roof work begins.JPG (137.54 KiB) Viewed 6767 times
2. Cleaned and treated.JPG (92.72 KiB) Viewed 6767 times
2. Roof work.JPG (94.91 KiB) Viewed 6767 times
3. defining edges.JPG (91.4 KiB) Viewed 6767 times
4. Roof work.JPG (97.51 KiB) Viewed 6767 times
5. Outer rail removed.JPG (114.33 KiB) Viewed 6767 times
6. Outer rail removed.JPG (95.01 KiB) Viewed 6767 times
7. New outer rail prep.JPG (110.56 KiB) Viewed 6767 times
8. Outer rail in place.JPG (114.33 KiB) Viewed 6767 times
9. Outer rail tacked.JPG (120.66 KiB) Viewed 6767 times
10. Outer rail in place.JPG (118.9 KiB) Viewed 6767 times
More! :rr:
11. More prep.JPG (94.7 KiB) Viewed 6767 times
12. More Prep.JPG (79.88 KiB) Viewed 6767 times
13. Pass side getting there.JPG (98.48 KiB) Viewed 6767 times
14. Cleaning up.JPG (98.13 KiB) Viewed 6767 times
15. Treated.JPG (118.97 KiB) Viewed 6767 times
16. Much nicer.JPG (96.79 KiB) Viewed 6767 times
17. Front Screen.JPG (124.74 KiB) Viewed 6767 times
18. Pass side front.JPG (130.99 KiB) Viewed 6767 times
And the last few for now.
19. Driver side Rear.JPG (91.02 KiB) Viewed 6767 times
20. Driver side.JPG (92.24 KiB) Viewed 6767 times
21. Driver side more.JPG (95.63 KiB) Viewed 6767 times
22. Lead removed and taking shape.JPG (107.44 KiB) Viewed 6767 times
23. More grot work.JPG (98 KiB) Viewed 6767 times
24. and more oles.JPG (86.66 KiB) Viewed 6767 times
25. Cleaned up.JPG (139.37 KiB) Viewed 6767 times
26. Driver side outer rail work.JPG (94.05 KiB) Viewed 6767 times
27. Ready for replacement.JPG (109.92 KiB) Viewed 6767 times
Great work, looking good 👍🏼
Thank’s Mark
Unfortunately, another step back yesterday. The intention for the trunk was just to wire wheel it back, quick patch of a couple of known areas, treat it and and paint it.
Not to be, once we got through all the grot and saw what we are working with. That’ll be a new trunk floor on order, then. :roll:
Making the start of race season is looking less and less likely now.
Stu wrote: Sun Feb 01, 26 10:08 am Thank’s Mark
That’s a bummer, but with that said, you have done so much so far, it makes sense to get the trunk right.
mygasser
Post by mygasser »
looks like you're on the steepest part of the slippery restoration slope stu, it'll be a great car once finished though. :thumbright:
neil.
mopar_mark wrote: Sun Feb 01, 26 10:39 pm That’s a bummer, but with that said, you have done so much so far, it makes sense to get the trunk right.
Yes, stood and scratched my chin for a good while, trying to justify just patching it up again, but the repairs are so bad and the rest of it is threatening to go in the near future, so I knew that the reality was there was only one correct decision.
It’s a bummer on time and the engine build I had planned is definitely shelved now, but I hope it will be worth it.
mygasser wrote: Sun Feb 01, 26 10:52 pm looks like you're on the steepest part of the slippery restoration slope stu, it'll be a great car once finished though. :thumbright:
neil.
Thanks Neil. Yes, someone did a James Bond move and turned the stairs into a slide about a minute and half after I stepped onto them…
Oh mate it looks like a major surgery :cry:
but the car should be a lot healthier when finished and something to enjoy for years :thumbright:
Hope so! Cheers, Ali.
Engine can wait, at least you'll know you've got a solid base for the engine when the time comes. :thumbright:
Cheers Dave, yes the engine is going to have to wait now, the pot is empty.
In better news, big thanks to Chris at GAS, managed to get me a trunk floor in double quick time. Ordered on Monday, picked up yesterday. That’s service for you!
I’ll post some more update pics at the weekend, it’s moving on quickly now.
Fabulous work there, that roof skin that came off looks quite good really, I have a similar task to do, have been putting it off since 2014, to remove the sunroof and fill the hole. I have an old roof to use to fill the hole. Great to see the panels are now available and easy to obtain through Chris.
The roof skin that came off is an absolute abomination of bad repairs in reality, Matt. I’ll try and dig some pics out. It doesn’t look too bad from the pictures here, as it’s the underside and covered in thick brush paint, but it definitely had to go.
Yes, Chris is definitely your man, so much easier than trying to to ship stuff yourself.
If you get bored and fancy watching the bones of the process, have a look at the link below and go to 13 minutes in. Tommy Boshers showing it pretty much step by step.
https://youtu.be/ZmEuHGKJu3E?si=17hvStxJRcSlbNBv
I think I watched that about 20 times before pulling the trigger. Way out of my talent zone, though, so very happy to have a good welder on the same site as me to be able to do it while I bob in and out to keep an eye on progress.
