Used to be Blue's Valiant
lough3969
Re: Blue's Valiant
Post by lough3969 »
thats a bananarama pain in the bananarama!
Pimps in the Front
Hoes in the Back
Chumps in the Trunk
68 Dart Post
Matt
Re: Blue's Valiant
Post by Matt »
Wow that's a long way out. My Quicktime bellhousing for the 360/TKO500 was spot on.
Re: Blue's Valiant
Yea I do seem to have got a bad one, I'd already had to rework various bit of it that didn't fit together.
Bozwell
Re: Blue's Valiant
Post by Bozwell »
I take it you checked the engine block mounting face with the dial gauge? and is the bellhousing is square to the engine block?
Matt
Re: Blue's Valiant
Post by Matt »
And i take it you’ve tried it without the adaptor ring in place?
Re: Blue's Valiant
Yes Matt I get the same readings with and without the adaptor ring. I still need to check the mounting faces are square before I commit to altering anything.
Re: Blue's Valiant
I am far from convinced you can measure that accurately by using that type of gauge in that manner. You are not at 90 degrees to the surface.
Re: Blue's Valiant
That concerned me too Dave but as it consistently returned to zero at the same spot I felt it was accurate? Getting it to sit at 90degrees to the surface was nigh on impossible given the space constraints. I did manage to have it square today to check the mounting face and that's too low at the bottom so I'll have to shim that level before I check the centre bore again.
Re: Blue's Valiant
I have a very small metric Dial Gauge if you want to borrow it...
I have never seen one that far out though...
Re: Blue's Valiant
if it was 90* it would show an even bigger runout....
so still wrong just wronger than measured
did you get it from summit?
in the past i have provided photo evidence of wrongness to them and they just sent another....
Re: Blue's Valiant
Came from Speedway about 5 years ago unfortunatly. Will try harder to get gauge set at 90 degrees next time...
Re: Blue's Valiant
There is a proper tool for checking bores. I seem to remember using one many years ago.
Bozwell
Re: Blue's Valiant
Post by Bozwell »
Dave999 wrote: Wed Nov 27, 19 9:35 am if it was 90* it would show an even bigger runout....
it works the other way around. it's known as cosine error. your measurement is bigger than actual.
Re: Blue's Valiant
so if i put my dial gauge at 45 degrees from parallel with a surface and move the surface 20 thou i will measure greater than 20 thou
but if it was 90 i'd measure 20 thou.... aaaaaah you have melted my brain
i'm off to read up....
15 minutes passes
Oh....yes my god.. yes indeed....
learn something new everyday
although the tip of the dial indicator compensates for "cosine error" up to a 20* lean from perpendicular
provided its the right shape....ahhhh never knew that either, suggest a cheap one from china probably doesn't but a decent euro or US made one probably does
right i should do some work....
Gareth
Re: Blue's Valiant
Post by Gareth »
Blue wrote: Tue Nov 26, 19 4:53 pm That concerned me too Dave but as it consistently returned to zero at the same spot I felt it was accurate? Getting it to sit at 90degrees to the surface was nigh on impossible given the space constraints. I did manage to have it square today to check the mounting face and that's too low at the bottom so I'll have to shim that level before I check the centre bore again.
Would a lever type gauge not be better than your plunger type for that situation? Shouldn't bankrupt you if you haven't got one as long as you don't go silly on spec.
