Blue wrote:That's a mess. You need to strip it and check a few things. I see there's a Mopar performance cam in there, which one? The valves have hit the pistons, you need to strip the heads and check for bent valves. Do you have sufficient valve to piston clearance? Are the pushrods the right length? Did you moly lube the cam and break it in correctly? Somethings not right there...
It is a performance cam but I dont know what size it is Blue. Has flat top pistons in too. If the pushrods are wrong then it's first I know. I didnt have anything to do with the engine rebuild, I was too ocupied with the boot floor and all the bodywork. Basically Phil had stripped the engine, cleaned every thing up, honed the bores etc. And rebuilt it using the same cam and other bits that were allready in the engine. The only thing bought for the engine was a new gasket kit, Milidon sump pan and pick up.
If there are clearance issues, would that not show up straight away. I cant understand how a valve can hit a piston wwhen the engine has been running succesfully for atleast an hour in total, maybe longer.
I'll carry on stripping it down this weekend.
