Uk law on lights
Personally I'll stick with the American set up for as long as I can get away with it. If I had to mod something I'd be looking to fit LEDs inside the existing light units, must be possible.
Rebel wrote: You don't need side repeaters and you also don't need hazard lights, they didn't become a requirement until the early '70's
Well i never new that :read2: :scratch: :read2:
Thank you all soo much for great info :thumbright: :thumbright:
Sublime For 40
Post by Sublime For 40 »
Check out these guys - try the interactive cars too ;
http://www.teslaynengineering.co.uk/amcar/CA_LSMC.shtml
One slight catch - they are very pricey.
It may be a case of you get what you pay for. They use very high intensity LEDs that are strong enough to show amber through a red lens.
Year One and Classic Industries do replacement LED bulbs too - in white, yellow, red and blue ! (about $14 each for 13 LED yellow)
Not convinced they would be strong enough to show through.
1970 Challenger tricky. Central reversing light. All red lenses that take twin filament bulbs that are 'low' for side lights and 'high' for brake and indicators.
If I just swapped the bulbs for amber I would have amber side, brake and indicators. Could leave side link off the outers but would still have red and amber when braking . . . unless someone has worked out a cunning plan ?
Matthew Oliver = MO(par)
If you've got a spirit that refuses to be tamed . . . YOU JUST MIGHT BE DODGE MATERIAL
Rebel
Post by Rebel »
A green bulb behind a red lens will show an orange light, you might be able to get away with a green LED in the rear lens to show orange when it's flashing.
Or, not sure if this would work, replace one of the rear lens's on the charger with the rear lens from an A series Opel Manta. Not many around now to try it with and I haven't checked out any measurements for size and fit. Might be worth investigating though
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
