What's your plans for 2015
Mossy68 wrote:
Captain Chaos wrote:Garage/Car Port Extension.
Driving and improving Mossy's old Ram.
It's your Ram now mate.
Perhaps start a " chaos Ram " thread so we can follow your progress ?
And let my thread slip quietly into the archives.
Ok,but I'll still think of it as yours....That Seat is the sliperiest thing known to Man :lol:
Knock down my poxy little garage and replace it with something more Coronet friendly :?
jerry
Post by jerry »
Get interior finished, fit fuel cell, sort a few other niggles, oh and sell my house :D
Finish the Fury, drive the Polara, import something and stop playing with myself......first 3 will be a breeze compared to the last one!!! :roll: :roll:
Get the motor back in, finish off the dry sump install, plus sort a few other jobs & give the thing a damn good thrashing...
mopar_mark wrote:Get the motor back in, finish off the dry sump install, plus sort a few other jobs & give the thing a damn good thrashing...
My plan is to flat & polish the new paint and bolt all the shiny bits on.
Buy a new clutch and fit that and the steel bellhousing from Blue that's meandering across the country in my general direction.
Then give the thing a damn good thrashing... ;)
Giving it a sound Thrashing???
Well Mark, it would seem like you and Steve finally have something in common then ;) ;) ;) ;)
What dictated the move to dry sump - more ground clearance? Getting the oil further from the Crank?
Fit new heads, go for 3.55 gears and beat on it!
jaymin
Post by jaymin »
Hope to get a shake down run in the coupe,
Cosmicfish
Post by Cosmicfish »
I got a list as long as my arm :(
I have a 1961 Landy series 2 in bits that I must get done and out the way
get the T&C snagging done then charm my boss into letting me use the company workshop to give it some paint.
And get to some meets looking forward to getting to that bit :)
Finish what I started over Xmas!
Get it running right!
Get it sounding like a V8 with no leaks!
New/updated cooling system installed!
Make Garys picnic, NATS and HRDs in the car and get at least 1000 miles on it!
Due to my 2015 calendar I think that's realistically it on finances and time!
Well I need to start saving to (hopefully) go to the USA for another road trip with Drew this year.
See how that (saving) goes then.
Not off to a good start. I just ordered some Koni FSD (Frequency Selective Damping) shocks for the Corvette. :oops:
The only thing that annoys me at times is the harshness of the suspension at low speed through town over potholes and not very level drain covers. When I see a pothole I can't avoid (even a shallow one) I grit my teeth in anticipation.
I have heard really good things about these shocks. They are supposed to be soft when you hit a pothole. But firm otherwise when cornering and at high speed.
http://www.koni.com/car-racing/technolo ... e-damping/
They get glowing reviews on every auto forum I have looked on. From Minis to Alfas. The only negative thing I have come across on the Corvette forums is that they tend to lower the car a 1/2 inch so if you have already lowered your car you can end up bottoming out.
Pete wrote:What dictated the move to dry sump - more ground clearance? Getting the oil further from the Crank?
Pete,
I wanted a dry sump from day one, but believe it or not, I had to say enough is enough at that time.
No gain on the ground clearance, as staying with the same sump, albeit modified. Better oiling method was the primary reason, also using the pump to drain the turbos.
Don
Post by Don »
Re-fit the hemi when I get it back from Roger, fit the new rear axle I've just had made by Hauser's, strip out and tidy up the trunk area, oh, and in the spring, take the roof off the bungalow and make it into a house
terryr
Post by terryr »
Don wrote:take the roof off the bungalow and make it into a house
snap ,not cheap is it,we will have to compare notes
