Noted thanksaussie pete wrote: Thu Apr 26, 18 7:48 pm Hi , when you change the core plugs,..use brass ones and that should
be the last time that they will need changing.
Change the 'o' ring at the bottom of the transmission dipstick tube,..these can perish and cause a transmission fluid leak
Engine/Trans what to consider before refit
- ScottyDave
Re: Engine/Trans what to consider before refit
