700 double pumper on a road car
GJUK
Post by GJUK »
Thank you.
GJUK
Post by GJUK »
I've ordered a fuel pressure gauge and fittings from torque, they should be here tomorrow.
I've also been reading up, could this be an issue (read from another forum with someone having a similar issue)
Blocked off fuel tank vent causing excess pressure to build in the tank and push the fuel pressure up
I have no fuel return from the carb to tank.
That said if my fuel pressure is too high (especially when running at high rpm as it is mechanical) maybe this is the problem...
Will find out soon :D
Jon
GJUK wrote:I've ordered a fuel pressure gauge and fittings from torque, they should be here tomorrow.
Jon
Jon,
Can you post the link to Torque on eBay as I can't find it?
Cheers Mate! :thumbright:
Jon
Neither do I- depends on the type of pump/ reg you have.
My return line is from my pump (mounted next to the tank in the trunk). I'm told this can heat up the fuel though and is noisier than a system that has a return from the carb.
GJUK
Post by GJUK »
Thanks, I appear to have no return at all. so it's a dead end and if the psi is a little high.... could cause leaking from the booster.
God I've learnt a lot about carbs in the past 3 weeks.
Torques.
http://www.ebay.co.uk/usr/torques_uk?_t ... 7675.l2559
J
GJUK wrote:Thanks, I appear to have no return at all. so it's a dead end and if the psi is a little high.... could cause leaking from the booster.
Torques.
J
Thanks..... :thumbright:
You don't need a return with a mechanical pump.
GJUK
Post by GJUK »
Thanks Dave.
Dave wrote:You don't need a return with a mechanical pump.
Dave.
As most our cars run mech fuel pumps ,which from my knowledge and experience prove to be reliable, then what could cause one to over fuel / increase pressure ?
Bozwell
Post by Bozwell »
looks like secondary float too high.
primary float height is quite critical for slow running and progression but with the secondaries the air speed is already up so you can go a little lower on the float height without ill effect.
GJUK
Post by GJUK »
Bozwell thanks, I will be trying this along with my fuel regulator tomorrow when all the car parts arrive at work, much to the receptionists joy. :D
Dave.
RPM.
You increase engine speed and it pumps faster. A stock pump does self regulate to a degree (they are weak) but aftermarket pumps in particular are built to deliver more fuel so you need a regulator to give you a constant pressure. Otherwise it is just going to go up and down with rpm.
GJUK
Post by GJUK »
Dave wrote:
Dave.
RPM.
Ahhh, you see it is not an original pump (it looks new). I was told that they self regulate but with aftermarket parts I guess you never know.
My regulator fittings are here today so fingers crossed guys... Really hope this fixes it.
Thanks for all your help.
Jon :read2:
An aftermarket pump can easily deliver 8psi of pressure without a regulator.
A simple cheap in-line pressure gauge in the fuel line to the carb will allow you to set the regulator pressure. Try it at 6 psi and set both fuel bowls to only JUST weeping out of the sight plug holes. Not dribbling out.
