Stroker rebuild
Carl
Post by Carl »
Steve wrote:Gotcha....just trying to learn from your thread Carl as its really interesting....
so the discussion at the moment is whether you should be able to run a 0.004" gauge round or a 0.002" gauge??
You got it, unless I haven't :?
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
Told you just to hone it and slap it all together again. ;)
Thanks men.... :happy1:
the radius of the bore should be 4 thou bigger than the radius of the piston
that means the bore diameter is 8 thou bigger than that of the piston.
the radius being 1/2 the diameter
Les Szabo
Post by Les Szabo »
Carl, gap your rings properly, carefully put it all together checking all the clearances including VTP and you will be fine and running sweet :thumbright:
Les
Mick70RR
Post by Mick70RR »
Did a bit of searching because I started to doubt myself.
Everything I read says you have 0.008" clearance.
This book explains how to measure piston to cylinder wall clearance.
http://books.google.co.uk/books?id=Ff4P ... edir_esc=y
Carl
Post by Carl »
Les Szabo wrote:Carl, gap your rings properly, carefully put it all together checking all the clearances including VTP and you will be fine and running sweet :thumbright:
Les
Yep I would be daft not to now ive come this far, need to get hold of a couple of old solid lifters for that then
*MMA-609*
:lol: not again !!!!! :lol:
This should be re titled the " piston to wall " thread !!!
As I understand it.
Carl took the block , pistons and rings to a reputable engine machine shop along with the pare work for the Ross pistons showing required dimensions etc.
the bores were honed to the correct dimensions ( according to Ross ) which resulted in 95% of the scoring being removed.
Rebuild time !!!
Correct Carl ??? ;)
Carl
Post by Carl »
Correct Gary
And we have 4 thou either side of Piston so in theory we are good to go.
*MMA-609*
Carl wrote:Correct Gary
Thank Bananarama! for that !!!!!
By the way. A circle only has 1 side. Therefore a PTW of 4 thou !! :D
Carl
Post by Carl »
No its a square with the edges rounded off ;) :lol:
*MMA-609*
Carl wrote:No its a square with the edges rounded off ;) :lol:
:lol: :lol: :lol:
Stop chatting on here and get that motor back together !!!!! :D
Mick70RR
Post by Mick70RR »
I'm sure you'll be fine Carl.
By the way how do you measure your bearing clearances? :?
Mick70RR wrote:I'm sure you'll be fine Carl.
No Mick. Please !!!! :D
Mick70RR
Post by Mick70RR »
Ok, I give in. :D
