Shoreham Airshow Disaster
- Don
- Location: DONNY SCOTT IN LANCING, ON THE SUNNY WEST SUSSEX COAST
Latest developments seem to indicate what I full expected to be the case .... engine failure. It flamed out up into the loop and had no power on the way out.
I cant get my head around a comment made by you Mark, where is the relevance in banning the I of M tt, sorry but I just don't get it?
Nope, that was simply lens flare from the camera.Don wrote:Latest developments seem to indicate what I full expected to be the case .... engine failure. It flamed out up into the loop and had no power on the way out.
Having had a secondary duty on a flight safety commitee for a number of years & having an insght to quite a few prangs it's best to leave these things to the investigation team, even if there is something blindingly obvious, it still has to be investigated fully using due process to give reasons.
Much has been written & said about this incident, the flap setting used being one of the most interesting with pilot notes being dragged out from dusty cupboards to debate the case.
Fuel load & subsequent venting.
Flameout
alsorted mechanical failures.
pilot incapacitation
Birdstrike
mis-handling of the aircraft (covers a lot that one)
It'll be roughly two years before the AAIB get a full report out, that will have all the I's & T's dotted & crossed, unlike the jolly old Daily Heil who belt out new & authoritive reports from their seemingly endless panel of experts on an hourly basis.
The policey changes to display flying is an interim measure pending the AAIB findings as is the immediate grounding of remaining Hawker Hunters within the remit. All will be constantly reviewed during the investigation.
Best pull up a sandbag & grab a brew.
Pic taken at Culdrose, same airframe, possibly the best looking of all the jets of the period.
Mike that is called Mike.
69 Dodge A108
73 Mach1 Mustang
69 Dodge A108
73 Mach1 Mustang
A very well worded piece by the owner of "Miss Demeanour" one of the best known Hunters on the display circuit.
Lengthy but spot on IMHO.
Following ill informed comments and inappropriate speculation by so-called "experts" on display flying and Hunters in particular, I’m breaking cover from media calls and emails to me.
What follows must be read in the context that on Saturday an aircraft crashed and not beyond that. I would have written almost the same words if the pilot had walked away from something other than a normal landing and no one had been injured, fatally or otherwise.
The AAIB will take what time is necessary to gather all relevant and perhaps what others might think irrelevant information, before even starting to piece together events. Only then will they go on to draw conclusions. Following that, they will undoubtedly make recommendations in the wake of their enquiry.
In the following I have used the expression “they will” but it is only my assumption of would seem logical, so take it as “they PROBABLY will”.
The AAIB will look at the operator’s Organisational Control Manual, (OCM) which sets out how an organisation operates its aircraft.
(At the end of this post, you’ll see the sections in the OCM for Miss Demeanour.)
They will look at the maintenance records, the After Flight and Before Flight (AF/BF) records which will show amongst other things, the pre-start fuel state, oxygen levels, Anti-G system nitrogen gas levels, etc.
The Flight Authorisation sheet will show the details of the planned flight, such as where the pilot intended to land after displaying. They will rebuild his planned flight as if they were flight planning it themselves. I would hope they would use an experience Hunter display pilot to do this, someone not connected to the organisation.
They will listen to the chain of radio communications from the departure airfield to starting his display. Just listening to what is said and how it was said will be factors, ranging from absolutely normal to there being intimations of other factors at play.
They will look at radar tracks along side those communications. Tracking around London from North Weald is flying in some of the most congested areas in UK General Aviation. Everyone else is also “going around” London but at less than half the Hunter’s speed.
They will analyse in great detail and probably develop a computer model of the display flight profile, from his positioning for the run in until moments after impact. This they can do using combinations of primary and secondary radar information together with photos and video from the general public. There is the possibility that any GPS in the aircraft will have recorded the flight profile. Nothing near a Flight Data Recorder but it could give track, speed and height information. They will look at everything they can which is external to the aircraft. Such factors such as visibility, birds or other aircraft that could have been in the pilot’s view. Anything that could have distracted the pilot or physically affected the aircraft. Photos and video of the jet exhaust, its heat haze etc can provide them with information. There will be things which even I haven’t thought of.
They will look at the pilot’s log book and any video they can get showing his previous displays in Hunters. They will look at displays he has flown in other aircraft. They will talk to people regarding personal details, medical history, occupational flying and to his Display Authorisation Examiner, etc. They will interview other Hunter display pilots to get an understanding as to what we do and the different ways in which we might go about displaying. They might even present those pilots with the information they have gathered and ask for second by second comments. They will obviously want to interview the pilot himself as soon as he is medically fit to be interviewed.
All this will take some months and can not be rushed. They may come up with an interim finding if there is something that can not wait for the full report..
The CAA also has to play its part by way of immediate and future actions. I can not fault what they have done so far.
As I write this is the status:
No flights by Hunter aircraft.
Vintage jet displays OVER LAND will be ..... “limited to flypasts, which means ‘high energy’ aerobatics will not be permitted.”
They are actively reviewing air show safety.
See
www.caa.co.uk/application.aspx…
I was just typing “ you’d think they’d give a simple link!” when this link came through:
http://www.caa.co.uk/SN2015003
That is the LEAST they could do. They might easily have applied the ruling to all aircraft over certain horsepower and weight, warbird or otherwise. They might even have stopped all air shows pending their review.
The UK has the Gold Standard when it comes to do with everything related to air shows.
Every year, the CAA holds seminars for Display Pilots and seminars for Display Authorisation Examiners (DAEs) such as myself. It is compulsory for DAEs to attend at least two out of three seminars. Display organisers may also attend these seminars.
The Military Aviation Authority (MAA) likewise holds annual seminars, to which civilian display pilots are welcome to attend. Senior officers from the MAA also attend the CAA seminars.
Finally we have the British Air Display Association ( www.bada-uk.com) who bring together civilian operators & pilots, military senior officers & pilots and display organisers, not only from the UK but Europe. BADA also arrange seminars.
Display Safety is the foundation stone of all these gatherings.
Apart from reviewing the previous year’s display activities and any incidents, safety procedures are reviewed both in terms of compliance and coverage. Whilst these events might have lectures on a wide range of air show aspects, they are also an interactive event where everyone can have an open discussion.
The British aviation community has been and continues to be world leaders when it comes to openness and examination of anything to do with aviation. Even the medical fraternity has taken lessons from this ability for introspection.
Comments about Hunters in general.
I’m often asked if they are difficult to fly. The answer is absolutely not. They are one of the most delightful and simple aircraft to fly. Yes, more demanding that a light aircraft because things happen more quickly. Their weight and speed makes inertia a big factor compared to a light aircraft. From a systems aspect, you could loose all hydraulic and electrical supply (they have two generators and batteries) and fly safely to land. In a Hunter in the UK, a suitable runway is no more than five or ten minutes away. I would go so far as to say that the skill level required to fly a Hunter is not as great as say flying a Spitfire. In a Spitfire or other big piston warbird, a pilot must have a definite feel for aircraft, an affinity for flying. In fact the further you go back in warbird aircraft age, the more difficult they become. The Hunter is at the peak of simplicity for all military jets of any type before moving on in time to later military aircraft.
With regards to the Hunter’s age, Hunter aircraft are still be operated by civilian contractors providing the military with services for which the military do not want to tie up their own more costly assets. Why, because they are simple and safe to operate. About the only downside is an axial flow engine which lacks the fuel economy of a by-pass jet engine.
Before the Hunters were allowed in to civilian hands, the type’s service record was examined in detail by the CAA, to assess its reliability. It was and I believe still stands as the UK’s largest exported military aircraft type and was revered by all countries and pilots who flew them.
It’s Avon engine is regarded as one of the most robust engines ever built by Rolls Royce. It is still used by power stations for auxiliary power generation. The London Underground also used them, I think again as an auxiliary power source or something to do with ventilation. Why? because they ran for hour upon hour with faultless reliability. While I was flying in the Fleet Air Arm, we had a Rolls Royce engineer talk to us about the Phantom’s engine. He had also worked on Avons. We still flew Hunters and I asked him how long could the engine run without oil pressure. I think his reply was something on the lines “we gave up try to find out after eight hours”.
Hunters, along with all ex military jets, indeed all ex military aircraft, are maintained and inspected beyond that called for by normal aircraft. That is NOT because they need it. It is because those who have the responsibility for the rules of their operation but do not understand the aircraft in fine detail, will see the buck stopping with them.
There is a public outcry for “something to be done”. It is natural. The question is where is the line drawn?
Accidents, at the most banal, it is not golf balls that kill people, it is the golfers who hit the ball. Why else do most Golf Clubs insist that their members have indemnity insurance? It must happen enough times that this is deemed necessary. It’s not cars and lorries that kill it’s the people driving. I am NOT saying pilot error, I’m saying that wherever there is an inanimate object under the control or lack of control by a human, accidents happen. Ban flying, driving and golf, problem solved.
There will be lessons learnt and things will change. Whether there is an over reaction we will have to wait and see. You will have been disappointed if you were expecting comments or views on what happened on Saturday. It is human nature to speculate but such speculation should not be made public where others might take it as gospel. It doesn’t help if that person’s speculation was based on the fact that they looked in their log book and saw they once flew a Hunter forty years ago.
Again, as in my previous post, my heart goes out to all the families and friends of those innocent people who were traumatised, injured or died as a result of the crash.
Jonathon.
Index of Heritage Aviation Developments Ltd Organisation Control Manual,
1 Introduction
1.1 Organisation Control Manual
1.2 Aims and Objectives of Heritage Aviation Developments Ltd
1.3 Contents and Amendments
1.4 Aircraft Operated
2 Personnel and Responsibilities
2.1 Managing Director and Chief Pilot
2.2 Aircraft Captain
3 Aircrew
3.1 Pilot Qualifications
3.2 Flight Authorisation
3.3 Licence Exemption, Annual
3.4 Licence Exemption, Training
3.5 Currency - Aircraft (Experienced Pilots)
3.6 Currency - Aircraft (Inexperienced Pilots)
3.7 Display Authorisation and Currency
3.8 Display Awareness
3.9 Carriage of Passengers
4 Documentation, Flight Management and Flight Safety
4.1 General
4.2 Promulgation
4.3 Documentation
4.4 Pre-Flight
4.5 En Route
4.6 After Landing
4.7 Oxygen Requirement
4.8 Flight with Unserviceable Equipment
4.9 Fuelling and De-Fuelling
4.10 Life Preservers
4.11 Ejection Seats
4.12 Abandon Aircraft Policy
4.13 Stores Jettison Policy
5 Standard Operating Procedures
5.1 Flight Operations
5.2 Weather
5.3 Charts
5.4 Self Briefing
5.5 Take-Off
5.6 Descent and Approach
5.7 Diversion
5.8 Crew Drills and Check Lists
5.9 Communications
5.10 Flights is excess of 250Kts IAS below FL100
5.11 Minimum Landing Fuel
5.12 Use of Brake Parachute
6 Displays
6.1 General
6.2 Display Minima
6.3 General Provisions
6.4 Display Manoeuvres
7 Engineering
7.1 General
7.2 Pre-Flight Requirements
7.3 Accepting Aircraft for Flight
7.4 Post Flight
7.5 Pilot Turnaround Requirement
7.6 Test Flights
8 Accident Procedures
8.1 General
8.2 Aircraft Accident
8.3 Actions to be taken
8.4 Subsequent Actions
8.5 Statements to the Press or other News Agencies
9 Maintenance and Flight Line Operations Interface
Appendix A Hunter Mk9/Mk58 Conversion Flights
Appendix B Hunter Mk9/Mk58 Technical Exam
Appendix C Ground School Training Declaration and Certificate
See
Jonathon.
1 Introduction
3 Aircrew
4.1 General
4.2 Promulgation
4.3 Documentation
4.4 Pre-Flight
4.5 En Route
4.6 After Landing
4.11 Ejection Seats
5.2 Weather
5.3 Charts
5.4 Self Briefing
5.5 Take-Off
5.7 Diversion
5.9 Communications
6 Displays
6.1 General
6.2 Display Minima
7 Engineering
7.1 General
7.4 Post Flight
7.6 Test Flights
8.1 General
69 Dodge A108
73 Mach1 Mustang
69 Dodge A108
73 Mach1 Mustang
- Don
I'm not convinced Mike, several people that I know well saw that flash, I didn't though. I must stress I'm not trying to sound like an "expert" because I am not, but I learnt a lot from my father-in-law who was a very accomplished stunt pilot
Don wrote:I'm not convinced Mike, several people that I know well saw that flash, I didn't though. I must stress I'm not trying to sound like an "expert" because I am not, but I learnt a lot from my father-in-law who was a very accomplished stunt pilot
flame outs, generally give a tell tale plume of white smoke as avtur is vaporising rather than igniting, plus sometimes an audible 'thud' as the core stalls followed by a deathly silence, generally indicating that unless remedial action is taken the aircraft will take you directly to the scene of the crash.
Having watched the video I am equally convinced that a flame out it is not.
In fact in some of the shots taken shortly before impact you can see the engine is actually producing power by the jet efflux.
As ever, the truth is there somewhere, we'll just have to wait on that sandbag, one lump or two?
69 Dodge A108
73 Mach1 Mustang
69 Dodge A108
73 Mach1 Mustang
- Cannonball
That is also what i meant to say mick, maybe this stunt stuff should always be performed over the ocean,,Mick wrote:I'm with mad machs on this one, maybe just stop the aerobatics at Shoreham, banning stuff isn't in my vocabulary, it's a slippery slope to the next thing.
Better ban steam engines...
http://www.itv.com/news/meridian/update ... am-engine/
or to really put things into some kind of perspective....
http://www.theguardian.com/science/2015 ... shed-on-it
69 Dodge A108
73 Mach1 Mustang
69 Dodge A108
73 Mach1 Mustang
