Mega block
Just sat and read this all the way thru for the first time.
Hats off to you Adam. Mega motor. Mega build.
Jees, I got lost at the talk of the paint
Seriously mate, well done to you and everyone else that lent a helping hand.
Don't you just love it when a plan comes together
Sounded awesome on the video too ( Bob, where did you get the porn music from? One of your old betamax tapes
By the way, where DID you get that hood from ? I want one !! (seriously, let me know mate please, already been thinking of getting a scoop for mine, but I suppose this would be easier
All the best mate, and good luck with your times
Jules.
MMA/750
MMA/750
Few probs with the pump shooter cams , the yellow one's supplied are toooooooooo big & flood the motor , the purple one's off the mighty are too small & bog the motor when you stamp on it...........
got the die grinder out @ shaved the yellow pump shooter cams down.
Finally got ready to give it a blast this afternoon.............
Stuck some fuel in & headed for the North Circ , No Neck buckled up & asked if i had a nappy he could use
, the torque is unbelievable , if feels like the old 440 with the 300 shot of gas
, sounds real deep & you can hear the gear drive , we got stuck in some traffic which panicked me a bit incase the motor overheated , the temp would'nt go above 170* which is good , No Neck took to the wheel & noticed a ricer up our arse , he tickled the peddle & the motor lifted the front till it broke traction , well pleased with the results , also runs on 97ron , oil pressure is pretty good & shoots up to 70psi when the rpms go up , the dominator is great on the street too , no issues whatsoever , will take it for a longer drive tommorow , can even hear ole Doris Day playin.
The Pit drives real well considering the motor in this , feels tame until you stomp on it , tis a sheep in wolves clothing & a right animal , obviously the track will show what it's got , but feels strong all the same.
- mopar_mark
gotta to love a dremmel momentBrutus wrote:got the die grinder out @ shaved the yellow pump shooter cams down.
Brutus wrote:Torque is unbelievable , if feels like the old 440 with the 300 shot of gas, sounds real deep & you can hear the gear drive , we got stuck in some traffic which panicked me a bit incase the motor overheated , the temp would'nt go above 170* which is good , No Neck took to the wheel & noticed a ricer up our arse , he tickled the peddle & the motor lifted the front till it broke traction , well pleased with the results , also runs on 97ron , oil pressure is pretty good & shoots up to 70psi when the rpms go up , the dominator is great on the street too , no issues whatsoever , will take it for a longer drive tommorow , can even hear ole Doris Day playin.
Great news Adam, really am pleased for you
170* is excellent, mine still makes me a bit nervous, if too much traffic about.
