How to set your ignition timing correctly
Mick
Post by Mick »
HI Miles
No 1 is different on a small block anyway, the pump drive can only go in about 4 positions and only one is right and mine is not on the c.line.
I am changing the heads soon, so i'll take a pic, also i will see what my other motor is when i finish putting it together.
I'm no expert and i most definitely dont have all the answers.
Mick
Alex
Post by Alex »
How do you get the drive can only go in a few positions? it can go in any tooth combo, sometimes the drive is reluctant to engage the pump that is the worst bit.
Mick
Post by Mick »
I've found that when i twist the drive, it turns quite a lot before it slots in again.
Alex
Post by Alex »
Onto the cam gear?ofcourse it does, if it goes to far, back it up a tooth!
As Alex says. Thats what i did. Worked fine, dont forget, the timing gears dicatate where the dizzy drive can slot in. in my case that geve me two options(following Daves pic) and one was closer to No 1 than the other and thats how it worked for me!
I was getting what turned into a migrain attack later that night Steve. I get irritated easy at those times. Sorry.
Mick
Post by Mick »
Surely that is altering the cam timing, i have never touched the timing gears on this motor. The last person that did was Geoff Hauser, to my knowledge. I wish i had more info on the motor, i'm not even sure what the cam specs are.
Mick
No Mick. Moving the dizzy/oil pump drive is not altering the cam timing. Lift the dizzy drive gear up and rotate it so that when seated it is lined up as described and as shown in the photo of my engine. Then the dizzy will point where it should.
MilesnMiles wrote:dont forget, the timing gears dicatate where the dizzy drive can slot in.
NO!
The dizzy drive can slot in in any position you like. It has nothing to do with cam timing or cam gears or anything.
Alex
Post by Alex »
:banghead: <--- Dave !
Mick
Post by Mick »
I was answering Miles's point about altering the timing gears Dave, i know that twisting the distributor does'nt alter the cam timing, just the ignition timing, as regards moving it, it's running fine so it can stay where it is.
I think i've said as much as i'm going to on this, the only reason i mentioned it in the first place is because i was curious but thanks for the replys
I'm taking the car to York next week, to test and tune it if it's dry
Mick
Mick wrote:I was answering Miles's point about altering the timing gears Dave,
I don't think he was talking about altering the timing gears and he was talking poop anyway (sorry Miles) although I am not sure because none of it was making much sense to me. This whole thing has confused the hell out of me. mainly because i thought it was a simple process and I had described it well.
You simply fit the drive gear as illustrated and then you turn the dizzy housing slightly until the rotor points to a cap post. Just like the photos of my own engine I showed you. It took me 30 seconds to do that standing in my dressing gown before breakfast. I can't make it more simple than i have.
I don't understand what your problem is and you can't articulate what your problem is. If you could explain why you cannot just do as described i could advise you. I personally don't think there is any problem with the engine or distributor.
Well thank Christ for that.
All I have laid out is the correct way to set up your timing from scratch. Every mopar that left the factory was set up this way. I don't give a monkeys if you can or want to follow simple instructions. I am not saying you HAVE to follow this method. I'm not forcing you.
Some people have found it very helpful though. Some other people just can't be helped.
Sorry Dave, it was lost in translation. I'm very much aware that the dizzy doesnt affect (effect?) the timing. after all, I set up my own timing gear camshaft installation etc..I simply meant that as I was following Daves original guide pictures that my dizzy didnt line up EXACTLY as in the supplied diagram. I'm not talking crap sometimes it just comes out in print the wrong way which I concede can be misleading.
I've learned more about these damn cars than I could possibly have wished too (due to wanting to improve it!) and much of that has been thanks to MMA members including yerslef ;)
