Dave Robsons Challenger R/T
- Dave-R
Yes. Made a bracket.Mick70RR wrote:Looks great Dave. Did you refit the overdrive switch and lights in your own bracket, and what's the other switches for?
The rocker switches are windscreen fan on/off and speed setting. No heater of course but even cold air up the screen will help clear it if it starts to mist up. I used to have them labled but can't get letraset the right size these days.
- mopar_mark
might be able to help you there daveDave wrote:Yes. Made a bracket.Mick70RR wrote:Looks great Dave. Did you refit the overdrive switch and lights in your own bracket, and what's the other switches for?
- Jon Connolly
- Dave-R
Update on tuning.
I have done a series of tuning tests now.
At idle (in gear @ 800rpm) I currently have;
14.5 AF ratio and 8 inches of vacuum.
Driving in top gear at 2000rpm (only on the center carb) I have 13.7 to 14.0 A/F ratio and 16 inches of vacuum.
At 4000rpm (outer carbs should be open some) I have 13.2-13.4 A/F ratio and around 17-18 inches of vacuum.
Plans next are to go up one jet size on the center carb, add a fraction more initial timing (going to try 19 initial and 36 total), go a touch richer on the idle mixture, and change from a 4.5 power valve to a 6.5.
- Dave-R
It is much easier with the data recorder and wideband sensor.
I did have 12.7:1 ratio on the center carb and dropped two jet sizes to get 13.7 for better mileage and cleaner plugs at low rpms around town. But with the outer carbs not being quite rich enough i will go one jet up to even things out a little more. I would like to get around 13.1 with all carbs open and don't really want to drill out the secondary plates any more.
