Parts
Parts
All got to
Precision Performance Hose Ends
2 x -12 90* £10.00 each
5 x -10 90* £9.00 each
7x -10 45* £9.00 each
5x -10 straights £8.00 each
2x -08 45* £8.00 each
1x -08 90* £8.00
3x -06 45* £7.00 each
1x -06 90* in black £7.00
1x -04 straight £4.00
4x -04 45* £5.00 each
4x -04 90* £5.00 each
2 x 3/8th hard line to -06 straight male (trans line adaptors) £5.00 each
5 x 3/8th hard line to -06 straight female ( as above) £5.00 each
2 x -06 to -06 45* female connectors £4.00 each
1x -06 to -06 female short straight connector £4.00
2 x Holley -06 long carb adaptors £6.00 each
1 x Demon -06 long carb adaptor £6.00
2 x Holley -08 long carb adaptor £7.00 each
7 x Holley -08 short carb adaptors £5.00 each
Demon -08 carb adaptors 1 long, 1 short £8.00
9 x -08 male T's £ 4.00 each
2 x -08 male to -08 female 90* £4.00 each
1 x 0 to 15 psi fuel regulator pressure gauge £8.00
1 x 0 to 30 psi fuel pump pressure gauge £8.00
Lots more fuel fittings, if anyone wants the lot come take a look and make me an offer
Raybestos 11x3 front brake shoes Part# 336PG £35.00
Raybestos 11x2 brake shoes Part# 280PG £30.00
B Body 66 to 70 front parking brake cable Raybestos BC92323 £20.00
Northern heater core, 70 to 74 B&E Body with aircon £30.00
Master Cylinder B body 67 to 70 with front discs, engine side outlets £45.00
Master Cylinder 73 to 75 A body with 10" drums £25.00
Alternator, double pulley, up to 70 £35.00
Alternator as above, broken brush £15.00
1 low beam,1 high beam £4.00 each
Rear diff rebuild kit 742 case £50.00
22 8 3/4 crown wheel bolts £18.00
34 3/8ths torque convertor bolts £20.00 Genuine Mopar
A&A 727 band strut £10.00
727 filter spacer £15.00
727 rear racing band £20.00
SFI approved flex plate 6 bolt crank £25.00
727 band £10.00
BHJ torque plate B & RB £80.00
Mopar performance breather P4529880 £8.00
Mopar performance rocker cover grommets pack of 7 £10.00
66 to 70 B body & 69 A body heater hose bracket £4.00
Demon rear bowl jet extension kit £5.00
MSD advance kit Part# 8464 £10.00
4 x FBO MSD advance bushing kits to give 10 and 14* £15.00
Competition Engineering back half cross member, 2x3, 60" long with a 3 1/2" drop £30.00
440 mechanical tach drive electronic distributor £35.00
Holley 4150 sec diaphragm kit part# 20-13 £8.00
used 400 timing cover £5.00
used 400 rocker covers £5.00 later type
rocker shafts with rockers £5.00
1x -08 90* £8.00
727 band £10.00
- dustymopar
'1 low beam,1 high beam £4.00 each'
Yes please!
Yes please!
'You can never go fast enough!'
1966 Dodge Coronet 440 c.i.
1969 Dodge Dart Custom
http://www.americansuperstock.co.uk/
Jeep Voltage Regulator required
Hi Neil, is there a number I can call you on?
Thanks
Edie Cross
07798 614931
Thanks
Edie Cross
07798 614931
