power steering pulley throwing drive belt
on the drive back with aspen the power steering drive belt came off twice, both times luckily it was retained on the power steering pulley shaft, the belt is a bit knackered now so the only one i had (which is a bit wider) was fitted, on closer inspection it looks like the power steering pulley is not quite inline with the other pulleys which is why it probably kept coming off, how can i get the power steering pulley back inline with the other pulleys?
- power steering pump pulley alignment.JPG (198.8 KiB) Viewed 2028 times
- mopar_mark
Put a straight edge against the pulleys, to determine how much they are out ?
Dependant on the amount you can space one pulley out, using a spacer of the amount their out. I am assuming the crank pulley is aligned & no other issues with alternator alignment etc.
May also be possible to remove material from the back of one pulleyor a combination of spacing & removing.
If a large amount, you made need to look at alternative pulleys or spacing of the power steering pump bracket or adjusting power steering bracket to suit
I had this aswell and I just elongated the rear holes in the power steering pump mounting bracket very slightly which allowed me to put a big screwdriver behind it while I tightened the mounting bolts and 'twist' it a few millimeters to line everything up. Dont think the brackets were made particularly well compared to modern tolerances..
Also worth checking is that the belts are the correct vee & widths for the pulleys.
The locally sourced Halfords/motor factor belts may appear to sit higher in the pulley vee, and will be a contributing factor to the belt wanting to disengage itself.
I got US style Dayco "Top Cog" V belts from Customville - just took my old belt to them and was able to souce a couple of exact size from their stock. These sat deeper into the vee of the pulley.
Worth looking into once you've got your sheave line correct.
1973 Dodge Challenger
MMA 616
MMA 616
- Demon James
Must be another one of those "MOPAR thangs" I had exactly the same line up issue. I spaced the rear most part of the mounting bracket out which got everything to line up. This was better than my first option, going to my belt supplier and asking for a V belt that goes round corners
the guy behind the counter just stared
the belt fitted isnt the correct one width or length but it was the nearest one in size that halfrauds had at the time, a mate of mine has got me a few thinner belts to try at the weekend hopefully one will fit in the pulleys better than the one shown in the picture, i will also try to straighten the pulley alignment out by bending the bracket if possible - all this depends on the weather if it does go to minus 14 i'll be inside!!
