RockAuto Discount Code - Expires 1 August 2013
RockAuto
Post by RockAuto »
www.RockAuto.co.uk is an online auto part store based in the US. Since 1999 RockAuto.co.uk has been shipping thousands of auto parts from over 200 manufacturers to customers all over the World. RockAuto is now also carrying a growing range of parts for European-market vehicles, which are available to ship from locations in the UK.
The www.RockAuto.co.uk catalog is updated daily with mechanical parts like brake pads and shock absorbers, body parts like bumpers and mirrors, interior trim like door handles and carpets, and major assemblies like steering gears, CV axles, and engine long blocks. Service manuals and CDs are available to help customers learn how to perform a repair. The www.RockAuto.co.uk catalog is expanding constantly. Someday it may be possible to build an entire car using parts from www.RockAuto.co.uk!
www.RockAuto.co.uk prices are low every day! Order online at www.RockAuto.co.uk 24 hours a day. Parts are conveniently delivered to your door. Have parts questions that must be answered accurately? RockAuto has excellent customer service agents ready to help you get the parts you need. E-mail service@rockauto.com or call 44 (0)2071 833854.
Office Hours (GMT)
Mon - Thur 12 p.m. to 4 a.m.
Fri 12 p.m. to 3 a.m.
Sat 1 p.m. to 12 a.m.
Sun 2 p.m. to 10 p.m.
5% Discount Code: C8704933724C
Expires: 1 August 2013
Please enter this code in the ‘How Did You Hear about Us’ box to receive discount. Please enter ONLY the discount code, no other words or numbers. Please note that orders using discount codes must be placed online and the discount code must be entered before an order is submitted to receive the discount. Phone orders are not eligible for discounts.
Dart Vader
Post by Dart Vader »
Ordered again from Rockauto, used my 5% discount as well
Finally worked out how to get everything from one warehouse, quite easy once you get the hang of it !
J
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
J
Come on the oh wise one, how did you do it.
Dart Vader
Create an account, then when choosing parts there is a tick box top right when you open the sub section, say, brake pads.
When you're not fussed about a brand per-se just tick all the boxes that are to the right of add to basket button for that style of part, both low to higher priced stuff is what I did.
Once you do your second part, repeat above and it will try and bunch stuff together from the one warehouse, doesn't always work as you might be buying old year car stuff as well as newer stuff. But I got some of my Dart parts coming from the same place as my missus 95 mustang bits and bobs
Seems to be that you need to create an account though as the reduce your cost button doesn't seem to appear when just surfing for prices.
Anyway, worked for me
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Dart Vader
Processing
To reduce the quantity of an item, adjust the Quantity column. To cancel an item, reduce the Quantity to zero. Please make all desired changes for each warehouse before clicking "Submit Change Request." It is not possible to submit a second Change Request for the same warehouse. We cannot guarantee Change Requests will be successful. If your order is too far along in the shipping process to intercept and you receive unwanted items, please return to this page to print return instructions.
Warehouse A
Quantity
1970 DODGE DART 5.2L 318cid V8
Cooling System : Radiator Cap
STANT Part # 10331 {11331} Safety Release Radiator Cap; Vented Cap (Open or Closed System) - 16 psi (SAE Range 14-18 psi)
16 psi Pressure Rating
Cooling System : Thermostat
MOTORAD Part # 206180 Standard
Temperature 180F; Alternate Temp
Cooling System : Temperature Sender / Sensor
STANDARD MOTOR PRODUCTS Part # TS17 {1972326, 1972549, 2426458, 2958320, 3179955, 387661C1, 4051140, 4051141, A1850, C3AF10884A, C3AF10884B, C3AF10884C, C3AZ10884A, C3AZ10884B, C3TF10884A, C3TF10884E, C3TF10884F, C3TZ10884A, C5DF10884A, C5DF10884B, C5DZ10884A, C5DZ10884B, D0TF10884B, D0TZ10884A, D1FZ10884B, D2TF10884AA, J3173363, J3179955, J941841, SW344, SW391, SW427, SW482, SW923, SWC482, SWE1012, U1850} - WITH GAUGE
Fuel/Air : Fuel Pump
AIRTEX Part # 6866 Mechanical Pump
Steering : Idler Arm
MEVOTECH Part # MK7042 {K7042}
Front
Steering : Pitman Arm
MEVOTECH Part # MK7074 {K7074}
Front
1995 FORD MUSTANG 5.0L V8
Brake/Wheel Hub : Brake Pad
CENTRIC Part # 10206270 C-TEK Metallic Brake Pads
Rear; GT Model; GTS Model
BENDIX Part # MRD600 Global - Semi Metallic
Front; GT Model; GTS Model
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
