Headlight conversion
GTXJim
Post by GTXJim »
One of my sealed beam headlight has packed up, so instead of replacing it, I was thinking of doing a halogen conversion, has anyone done this, if so what tips have you, I've only got two 5.75" headlights dip and main.
Hell Yeah!! I'm a Redneck
Re: Headlight conversion
GTXJim wrote:One of my sealed beam headlight has packed up, so instead of replacing it, I was thinking of doing a halogen conversion, has anyone done this, if so what tips have you, I've only got two 5.75" headlights dip and main.
Jim, it's easy to do, did it on the Charger a few years ago.
...just use relays for main and dip to reduce load on your old wiring.....
mad machs
Post by mad machs »
This guy does conversion kits, cheaper if you make it all up yourself mind, but it is a tidy solution.
http://www.brightlight-customs.co.uk/ot ... hting.html
As Pete said, relays are the way to go, pretty much essential IMHO.
Mike that is called Mike.
69 Dodge A108
73 Mach1 Mustang
GTXJim
Post by GTXJim »
I'm very wary about electrickery, so do I rewire with fused relays, or would normal relays suffice and where is the best place to buy all the gubbings ???
Jim,
Regular relays will be fine, they are only acting as a switch using low voltage.
good for all the gubbins ...
http://www.vehicle-wiring-products.eu/
GTXJim
Post by GTXJim »
What about Bi-xenon bulbs???
GTXJim wrote:What about Bi-xenon bulbs???
Are they not a combined High beam, Low beam ?
Don't see why there would be a difference ?
No doubt Will the Electrikery Wizard will be along soon ;)
ANTON
Post by ANTON »
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Xenon = a xenon bulb for low beam and a halogen bulb for high
Bi xenon = a very bright bulb with a shade or filter mechanism that cover half half the bulb during low beam and move out the way for full bulb full beam operation
So a xenon light is basily an out side industrial flood like you see at the football ground
It's has a ballets (starter) that steps the 12v to 20,000v to start it then ones on 85v to run.
Positive
There bright , use less engery too run compared to halogen , last longer
Negative
There expensive. You will see cheap on eBay but pay peanuts get monkeys
All new cars that have them have to have headlight washer clean system so could be fun at future MOT time. Take a while to get going compared to halogen. Funny blue colour. Loads for sale are techanikly illegal but so it 71mph expect to pay £85 for 1 x bulb
I hate eletrics Bananarama! cables everyware
mad machs wrote:This guy does conversion kits, cheaper if you make it all up yourself mind, but it is a tidy solution.
http://www.brightlight-customs.co.uk/ot ... hting.html.
Ooh. I like that.
Current Charger status - "Working !"
GTXJim
Post by GTXJim »
LET THERE BE LIGHT.......... all done and working a treat, thanks for the advice fellas :thumbright: :thumbright: :thumbright:
