Lower control arm
kma176
Lower control arm
Post by kma176 »
When rebuilding Lower Control arms using the stiffening plates and re-welding the tops anybody any idea how tight the adjuster arm should be???
Mine are able to rotate but only with grips and not by hand.
No binding and pretty smooth all the way just tight.
Any help appreciated before I get them powder coated.(':help:')
You'd normally be able to turn them by hand. I guess the metal has moved around during welding and they've gone tight. As long as they can physically move It will probably be ok, once you've set the ride height they don't need to move again.
kma176
Post by kma176 »
Thanks Blue
Yeah that's what I thought they do move smoothly just a bit tight!!
68Roadrunner
Control arms
Post by 68Roadrunner »
Are the plates available to buy, or have you made your own.
kma176
Post by kma176 »
Stiffening plates and swaybar brackets available:-
stiffening plates from P-S-T.com $16.00 part No LCAPLTMOP621
also from Mancini Racing or get them through WASP
68Roadrunner
Stiffening plates
Thanks for that kevðŸ‘￾
people often deliberately tighten them up again
very loose is indicative if splayed arms
