I have a 904 gearbox that was refreshed with a rebuild kit and new fluid two years ago (350 miles max).
I've already decided that im going to stick with the 904 (727 not really needed on the A body weight or for the amount im using it).
Also decided that im going to go with a floor shifter!
So, wondered what peoples shifter preferances are, and why?
As its a stock box i've also started looking at shift kits to try and get the gearchange a bit better.
The obvious one that seems to pop up is the Transgo TF2 and TF3 kits.
As above, peoples preferances and why, would also like to understand the 'seat of the pants' difference you felt post install?
Lastly,
End goal is built 360 or stroked 318 to 390/392.
What would you guys recomend in terms of upgraded internals to help with box longevity and performance (say 400hp/400ft lbs for ref)?
Much Appreciated!!
