need advice pls rear brakes
The -Dools
Post by The -Dools »
hi Guys, ok so original rear wheel cylinders weeping, order x 2 arrive with 'oval shaped backs' don't fit, so get another pair they fit, great x 2 rears all back together, adjusted up ready for bleeding , this is where the problem started, it seems the travel of the pistons inside cylinders is too long and fluid is leaking out from the rubber seal, so i am flummoxed are the pins now too small or are the cylinders poorly made, they are Raybestos cylinders from rockauto
any help ? any advise ? any suggestions ? thanks in advance TD
Re: need advice pls rear brakes
What car?
Can you post up pictures?
Sounds like the wrong Slave Cylinders to me.... have you compared them with the originals you took off?
Pete wrote: Fri Jun 28, 19 4:50 pm What car?
I'm with Pete on this one. compare old and new together.
The -Dools
ill try for pictures today, master cyl is new to go with disc on front and drums on rear, originally power boosted
its a '68 GTX
sounds like something is missing or you have not adjusted the adjuster up far enough.
did you use 1o inch drum shoes in 11 inch drums or do the drums have a massive lip showing a lot of ware
wind adjuster until you can just fit the drums over and go from there.
i don't think there is any difference between the cylinders in 9 10 and 11 inch drums other than the bore and the fact that depending on the diff they were most usually mounted on they have either perpendicular pipe going in or angled pipe going in.
raybestos are a good brand
rockauto carry so much stock that sometime they get it wrong for example the seals for manual steering boxes what they list is 2 seals the size of a sourcer that are obviously not right
yet looking up the ones you actually need they are stocked.... just not for mopars.. this has been wrong since 2012...
anyway
take a picture and we can compare it with Image
