Pinion angle wedges/shims
Goblinking
Post by Goblinking »
Hello Sirs,i need to adjust the pinion angle and the easiest thing to do seems to be to use shims/wedges.
Does anyone in the uk sell them?
Rockauto dont and it seems as if it's getting harder to order from the other USA websites.
Re: Pinion angle wedges/shims
Hauser Racing may have some in stock.
I did discuss these recently with them, but we used new Perches instead.
Goblinking
Thanks Pete.I actually have the new perches to do the job properly,but i can't weld.If there was a suspension specialist up here i would use them.
Where are you based?
The MP perches are not a lot of cop either, the locating holes for the pins are over-sized, so not very accurate....
Goblinking
I'm up in Sunderland.
when i lived in newcastle 25 years ago if i needed anything welded, mainly VW front axles at the time. i went to see George at Microblast.
so for old times sake i looked the business up. seems to still be there, down at the end of the lane behind safestore self storage central Newcastle
last railway arch before you get to UNDER the Redheugh bridge on what used to be forth goods yard behind the times square carpark off the A695
he also runs or works or worked for for CF recovery
owner of the first mobile phone i ever saw....about the size of a loaf
