70 Challenger splash guards
- Stu
No idea if that’s the correct name, can’t find them in the manuals, but I need a pair of the small panels that cover these holes in the inner wings, plus the clips.
Ta.
Ta.
- IMG_0539.jpeg (172.05 KiB) Viewed 1106 times
Re: 70 Challenger splash guards
I made my own out of some 2.5mm(??) sheet from an old plastic packing crate
a bit of heat to get the shape, they don't sit quite flat despite how they look in the photos
I did already have the spring clips from the original installation
- 100_2393.JPG (122.19 KiB) Viewed 1066 times
- 100_2514.JPG (195.35 KiB) Viewed 1066 times
- Stu
That looks pretty tidy, but no clips here either, so will need to source them as well.
Can’t find anyone repopping, that I can see. Bit frustrating.
Hey Stu,
I did the same as Si, just cut some new rubber but put some M5 washers under the heads so it's easier to remove without ripping the rubber.
It looks like the clips are available, hopefully shipping isn't too bad if they're in a jiffy bag. if it was Summit they would be in a bag, inside a small box, inside a medium box just to inflate the shipping
https://www.detroitmuscletechnologies.c ... ield-clip/
Stuart.
Stuart.
- Picture2.jpg (38.83 KiB) Viewed 1046 times
- Stu
Cheers Stu
I’ll see what I can turn up if no one’s got any.
- Stu
“Inner fender shields” I’ve finally found them as!
Now to find a pair somewhere…
are you missing these as well
https://www.ebay.co.uk/itm/375212518673 ... LvEALw_wcB
i.e if ordering kill to birds with 1 stone
i have a set of A body ones but different from the ones above
- Stu
That’s a good question, Dave.
Quick answer is… I don’t know!
I’ll have a check when I can see it.
MCT (Musclecar Technology) in the States do lots of stuff like that. They make them using originals as templates
- Stu
Cheers Steve, appreciate that.
