Graphics help
Graphics help
Morning.
Anyone on here able to produce vectorised images? my photoshop abilities aren't high enough quality for purposes.
Cheers. :thumbright:
Re: Graphics help
Hi Stu, what do you need?
Re: Graphics help
I made a vector image of a gasket once
I scanned the gasket in 3 parts
knitted the images together into 1 big gaskets sized image and cropped out the gasket
converted it to black and white
cleaned up the edges in paint at pixel level i.e just zoom in and fill in the missing dots
used a website to turn it to vector graphic
sent it to the gasket cutter and he said ah its a bit complicated and he never got back to me
a proper 3d part is much harder
if you can build it in some cad program crealty slicer or similar will convert it from a solid into vector based STL file for 3d printing.
depends what you want to do
i usually just get my son to do it
Re: Graphics help
I've got Autocad which produces vectorized images. Is that any good?
Re: Graphics help
Dave999 wrote: Mon Feb 19, 24 8:59 am I made a vector image of a gasket once
couldn't agree more.
Re: Graphics help
Thanks Gents
I have to provide a sign company with Vectorised Graphics to get vinyl decals produced for the car.
My photoshop design is nowhere near good enough quality and they have said to avoid pixelation they will need it in. Vector format.
Not something I can do, so was hoping someone may be able to help it point me in the right direction.
Don’t want to get it wrong or it will look Bananarama!!
Re: Graphics help
Sounds like you need Adobe Illustrator, that uses vectors for graphics. Unfortunately I don't have a copy.
I'm sure you could use Photoshop, save it as a large image.
Re: Graphics help
corel draw? see if you can get a time limited demo
or sign up and cancel before first month is charged
.SVG i think is what you need
Re: Graphics help
I have Illustrator. Bit tied up this week with exh install.
Re: Graphics help
gmopar59 wrote: Tue Feb 20, 24 8:16 am I have Illustrator. Bit tied up this week with exh install.
Aha, cheers. 👍 Might be worth a look at some point!
I’ll check if I have access to Illustrator with my Photoshop deal, I never really realised that’s what it was.
Re: Graphics help
Found out I can get a free 7 day trial of Illustrator, then cancel without charge. :thumbright:
As long as it isn't too complex to use, I will give it a go and see if I can do it myself.
Cheers All. :salute:
Re: Graphics help
Give me a shout if doesn't work out.
Re: Graphics help
gmopar59 wrote: Wed Feb 21, 24 8:30 am Give me a shout if doesn't work out.
Appreciate that, will do. :thumbright:
Re: Graphics help
Nice one stu.. try before you buy....
just keep saving copies so you can go back to the last good one after a disaster
i have a vision of you swearing at the PC at 3:30 am
Re: Graphics help
That’s me anyway! :smash:
