Can anyone throw any light on the origin of this engine number?
Doesn't seem to tie up with the sticky listing?
Numbers are 3830930.440.6
4T 440T
LGW7
MH.3 30
Engine Number
internet says that block casting is
1968-1978 440 with steel crank
or 1973 to 1978 440 with cast crank
comments indicate RVs had these with cast cranks
4T indicates its a 1974 I think
if that was LC rather than LG it might mean low compression which fits with the RV end of things
some where in that bunch of numbers it is supposed t indicate a plant that produced the engine. T Trenton?
Just stuck 3830930 into google mind so it could all be cods wallop
I think its a Low compression 440 out of a 1974 RV....but I am in no way qualified to think or say that
you'd need head and crank numbers to really be certain
Engine number
Owner found 4006452 on the head, cannot see anything on
Crank.
What would such a motor be worth if I was to make an offer for it, presuming it is a runner?
Crank.
ChrisWitor
again based on digging
4006452 is off a 76-78 400 or 440 motor originally
if it hasn't been to bits or had a head swap
that puts it right in low compression torque monster territory out of a great big vehicle.
with a cast crank
any big displacement motor is worth quite a bit these days
i.e 400s and 440s seem to be really quite hard to come by
but really I have no idea. I know my six cylinders and that's about it
with a cast crank
The heads are good, the '452 heads are similar to the '906's used on 68-69 and the 346's used on 70-71 383 and 440 motors, except the '452's have hardened valve seats.
Yes, it will be a low compression motor, and may have a cast crank. The blocks are all good, so this could be a good basis for building a nice 440.
