Electronic Dash Voltage Regulator - where from?
deppmobile
Post by deppmobile »
My Googling is failing me.....
I need to replace my dash voltage regulator, but can't track down the electronic version. Any links?
Thanks!
Gerry
Re: Electronic Dash Voltage Regulator - where from?
adrianp
Post by adrianp »
Used this one on my '66
https://rt-eng.com/index.php/RTE_limiter.html
adrian,
RTE here also.
deppmobile
Perfect!
MrNorm
Post by MrNorm »
I converted my own - it was popular before people sold them already done!!! Actually not very difficult, depending on your year and model
sublimemike
Post by sublimemike »
I'm sure there was a post on here a while back about making your own up with parts from now defunct Maplins?
http://www.farnell.com/datasheets/1941079.pdf
this looks about right although checking out a few is sensible to check the pin outs can be matched to your board
fixed 5v output voltage regulator needs to be able to do a good few amps and needs to have a max input north of 15 volts
This one
up to 20 volts in
5 volts out
3 pin
VIN
V OUT
GND
mounting tab is VOUT as well...beware
obviously they last longer if a heat sink is added
beware the heat sink/mounting tab could be ground or output voltage check how it mounts and insulate if necessary based on your chosen one
MrNorm
Post by MrNorm »
ahhaha.... thats it.... he has chosen 1 with the mounting tab at ground makes more sense....
deppmobile
Derek wrote: Sun Sep 27, 20 5:43 pm I think this is the one I used
https://www.ebay.co.uk/itm/DC-DC-Conver ... Sw5cNYcSC7
I went for this - works perfectly and £4! (Mine won't ever be a concours winner..... 8-) )
