Main bearings for 440 oversize
SPIKE
Post by SPIKE »
Does anyone have the part numbers for Oversize main bearings for a 440 block? I have tried emailing King but no reply. are there any other manufacturers?
By Oversize I mean bigger on the Outside Dia not Undersize for smaller crank journals.
I have found someone with the equipment to line bore a 440 block to the std size or as in this case to a larger size, useful for when a bearing has spun. they can re size caps and machine for steel caps if needed.
Of course if there is anyone out there that has them on the shelf then shout up.
