technical stuff to confuse you even more
acrylic or 2pac?
ooh, theres some interesting bits & bobs in there.
We have a Sikkens dealer near me, sadly Bancrofts has gone now
so some of this stuff might be well handy to know up front.
I'm thinking of building my own IR heater array (I can't afford to buy one) so I'll have a buz through thier IR curing guidelines as it will hopefully give me some pointers and an idea whether its worth doing or not...
Guys,
can you recommend anyone who is a whizz at body work (not that mine needs much) and an excellent sprayer who ISNT going to absolutely have my pants down when the bill is drawn up?
Bodywork wise, I need the obligatory trunk floor, rear screen removed and metal surround repaired, a patch but in at one end of the rear bumper then a small repair done on drivers side sill.
I then want the car sprayed white (smae colour as it is now) and a red bumble bee stripe stuck on.
Any ideas
Mucho Gracias
Any ideas
Mucho Gracias
Sorry to confuse you Alistair, I ment polyester basecoat!
Just to simplify matters I use R-M Diamont Basecoat and R-M Crystaltop clear.
For Straight colours, R-M Uno. They two pack materials, tough as old boots, the colour match is spot on every time (when I've got the car in front of me, or you need a factory original colour).
How far are you prepared to go for a paint job Clivey? I'll see if I can get a name for you.
PAINT
Bit of a late reply, 2 pack is the way to go, as well as what the other chaps have mentioned, theres 2'3 tricks u can do with 2 pack
If youve any GP panels on yer motor u can add a plasticer which allows the paint to flex with the panels also increase the gloss level
on the last coat if really building a hi build up on a solid colour add some clear laquer to last coat(s), once paint has cured/ dried, nib off with some fine wet n dry& soapy water, then buff up with a good polish compound , Farecla g7 is a good 1 to use Once youve flatted the paint work down allow to stand for a few hrs or over night allows the paint to re settle down after being worked if not baked dry
regards
regards
Never had a prob with g7 Alister,Ive always used it with a proper buffer that runs at right rpms, plenty of water on the panel as u buff, stops the swirling , keeps paint surface cooler avoids those odd horrid burn marks if not carefull, ive used g3 always seemed to have to work it more, but its every1s liking to what product.
I always finished off with a water based wax, then a good coating in MER wax, ands a capfull when washing.
Regards
Regards
