Second sensible question
AllKiller
Post by AllKiller »
Dave, doubt it....the fans they have blow air at incredible velocity... :?
ALL KILLER NO FILLER
Probably the way the rev the nuts off the engine without enough load.
Dave wrote:Probably the way the rev the nuts off the engine without enough load.
Thats about it, alot of people we know (engine builders included) dont like dyno's
Just in case they under achieve? ;)
AllKiller
Post by AllKiller »
Yeah that sounds about right Kev :lol:
I thought the Dyno used a 'load' or how do they get a reading
the old type dyno,s did used to be loaded for sure, i think the modern ones maybe not
Jon
Post by Jon »
there has to be a load on or how would you measure it? how would you tell one engine from another with no load on?
its more likely too much load that makes them more likely to break on the dyno than too little
no engine should break on the dyno, what it does do is show you any immediate faults, and some can be terminal
I think most modern dynos are just a solid steel drum or a steel container full of concrete? I don't think they have the rear wheel load that the original "Dyno Don" water turbine machines had.
AllKiller
Post by AllKiller »
Dont think a Dyno would be any worse than doing a burnout.....
AllKiller wrote:Dont think a Dyno would be any worse than doing a burnout.....
Too true!!!!!!
