You don't have to change the axle in any case. You just bolt in whatever LSD unit is made for that axle. I recently fitted an Auburn unit to my mates Charger.
Check out Randys Ring and Pinion. They have a couple of different LSD units on their site. Wil can supply you one too.
Diff advice
- Rogue Trooper
- Dave-R
I didn't. He took it away to fit himself after i fitted that and a new ring and pinion. He might have used LSD oil or an additive.Rogue Trooper wrote:A quick hijack,
Dave what LSD axle fluid did you put in your mates charger,
For myself I use tractor oil for LSD axles. It is much cheaper. Does the same thing. £13 for a gallon.
