Manual valve body with low band apply - 1st gear question
- Cannonball
- Dave-R
Bolt-in sprag kit is the way I would go in the future. Only $100. Cheap insurance.
http://tcsproducts.com/index.php?page=s ... &Itemid=30
- Cannonball
dave, the bolt in sprag dont do jack, back in the early days when 727 cases started gettin damaged by the sprag outer body turning in the case, someone came up with the bolt in sprag it was to repair a damaged case nothin to do with performance it saved scrapping an otherwise junk case, a bolt in sprag will roll just like a standard one lettin the high gear clutch drum speed out off control, the only thing to safeguard your floor pan and legs is either an ally high gear drum / or the new steel type drum they dont explode,
- Cannonball
i would think you will be ok but dont be brutal
good article on why 727s can explode
http://www.forabodiesonly.com/mopar/sho ... php?t=2167
I have low band apply and i dont have 500hp to worry about
