Tyre choise?
Tyre choise?
Im looking into putting tyres on my duster, looking for the best of both worlds track and road use! size is 325/50/15.
What is a good tyre to use, looking at M/T or BF G.
Any input is appreciated.
Cheers Mo.
Cheers Mo.
check it out
http://www.hoosiertire.com/specdrag.htm#QUICK%20TIME
scroll down to QUICK TIME D.O.T. then click on the D for a pic
I found Hoosiers very bad to use as street tyres.
Fitted my set on the GN, backed out the drive, drove away to merry clicking-clacking of chuckies picked up by the soft rubber, getting shed into the wheel wells. Stopped at a set of lights, nailed it with some boost and it was sideways city.
Dreadful.
Fine once you put some heat in them though, just had too short a sidewall for me.
Stuck some cheap Diamond Back retreads on and they would cut through dampness on a wet road and grip. Astonishingly good, and lasted a while.
Bear in mind, this was 10-12 years ago though.
Dreadful.
Just wait till you find yourself trawling through Ford swap meets for all your Aus Ford buddies back in the UK .....
Actually, there was a Hoosier dealer here in the UK when I bought mine. I phoned up and asked if they had the size I needed. yes, they had two. Price £119 each but seing as how they were going out of business and there would be no more ... £119 for both plus free delivery.
But, as you point out, that was so last century.
And to think for years I was the only modern guy on here ... with the exception of James K.
