Ok guys, I have no radiator at the moment.
The cars a 440 charger with a modded enginge.
Could I use a large radiator from another vehicle and use a seperate trans cooler? just temporary until I can afford the original/performance Rad?
Please say I can!
I do a lot of praying recently!
Radiators?
All I want to do is save a few quid at the mo, what I could do with knowing is there another rad I could fit from another car that would do the job for a while until I can afford a good upgrade?
The engine I have has had many upgrades so (and I should not really skimp on this but need to save the dosh) is it possible to get something?
I can run a seperate trans cooler.
I went looking through our parts department and found a couple of big rads, some with trans coolers in, these would come very cheap!!!
Any advice or if you have a rad that I can recore etc let me know!
Have a chat with Duncan I am sure he will have a old big block rad with a knackered core get it recored for about ?120.00 ( thats what mine cost) with a low hieght core this effectivly doubles the coolin capacity of the rad run with a seperate trans cooler (bigger the better) Stick a big leccy fan behind the rad and forget your coolin woes.
Ive got a big block Rad for a B body you can have for ?50. Its ok and was re cored about 6 years ok. The bottom hose is driver side but you can either get a matched water pump or get the outlet location moved.
Also got a brand new elec fan you can bolt on for ?30.
call me on 020 8748 7690 if interested.
