Magnum 500's
's alright Adam, you stick to your plumbing and I'll stick to me technical drawingAdam68 wrote:RobTwin wrote:On a 4.5" pcd wheel (which yours should be), the centre distance between 2 adjacent bolt holes is 2.65" or 67.2mm
Adam, the 4.5" measurement is the diameter of the circle that the studs are arranged on (pcd - pitch circle diameter), so the distance between 1 & 3 for example would be 4.28" or 108.7mm.
So there.
