Needing a new clutch for my roadrunner. Its got a 440 and an A-833 4speed manual. Before I order my new clutch, can the number of splines on the main drive pinion be determined by 'decoding' any of the cast or stamped numbers on the box or will I need to drop the box off?
Thanks
18 or 23 spline?
The casting number on the bellhousing is what you need.
Counting the number of teeth on the flywheel will back it up.
Have a look here, it should tell you what you have.
http://www.brewersperformance.com/products.asp?id=28
- Cannonball
i would think its a 23 spline, if yer bellhsg is cast iron 11"clutch, ally "10.5 clutch, hemi/sixpacks got the 18 spline,
A torqueflight
I used Centreforce clutches in both 18 & 23 spline configuration. Light pedal throw; you have to shorten the travel to stop them "turning inside out". A block under the carpet will do this.
Not really up to it on the strip in my opinion.........and expensive.
