While I am waiting....
Jeff
Post by Jeff »
For membership to a Canadian club, I played with Potatoshop...
Now that looks superb, Have at it!
Jeff
Post by Jeff »
Can't be that difficult, can it? Could I use the stock beam? I know some of the blokes way back used to use A100 axles...
Narrow the rear a few inches, Or do I have to? Keep stock springs.
It's the look I like. Whaddya think?
Is the stock beam mounted under the springs? If it is then it's dead easy to raise the front up a tad. If you want to radiarise the rear arches, then you'd want a wider rim in the right offset to move the wheel out a bit. No axle narrowing required. All in all I don't think it would be that hard to do at all.
jeffs just bloody teasin again blue,
did you buy the gremlin jeff??????????????
Jeff
Post by Jeff »
Thanks for the phone call Blue..... Just waiting for a reply on the wheels. WOW! they is "well cool" Will be measuring it all up this weekend.
Jeff
Post by Jeff »
Just going out to have a measure up for the front beam.... And I have to make a decision on wether to have the rear arches cut out! :shock:
Thing is, I can change the whole look of this truck, quickly without chucking too much money at it!
At a later date, once I have moved. A 400ci will fit in the bay with no mods to the sheet metal needed! So, I can finally see a plan for the ol truck!
