Axle ID & service info needed
Matt
Post by Matt »
Hi all,
I need to replace the LH rear wheel bearing on my 70 Coronet wagon (318ci) . I've looked at the axle , but I've only got a '69 workshop manual, and it doesn't seem to feature this type . The axle is the Dana style with the rear removable cover , & I think it's probably an 8.25 .
I need to pull the LH halfshaft, but there's no bearing retaining plate like an 8.75 , and no end-play adjuster on the RHS - in fact it looks like I would have to pull the whole brake backplate & remove it with the halfshaft & bearing- however I think it's more likely there's a halfshaft retaining clip inside the diff housing.
Has anybody got a 70-up workshop manual that covers the wheel bearing replacement procedure, and could they either describe it, or get scans or photocopies to me ??
Thanks in advance
Matt
Is it not the 7.25" axle?
Let me know if you need the rest of that section.
Matt
Post by Matt »
Hi Dave ,
thanks for the info - I was thinking maybe it was a 7.25 myself, then I thought - 'station wagon with V8 - maybe a bit small ??' . I don't think it's a 7.25 , as there are no bearing retainers visible on the brake backplates, and no access hole in the halfshaft flange. The backplates are bolted directly to the axle housing , with no other hardware attached by those nuts/ studs. The halfshaft appears to pass straight through & be retained as if by magic.
I looked at an A100 van manual yesterday, & the 8 & 3/8 axle design shown is such that the halfshafts pass straight through a non-taper roller bearing, & then locate in the diff where each halfshaft is retained by a big circlip-type thing. The whole thing looks very similar to what's on the car , so I'm going to pull the diff inspection cover & have a look.
A quick inspection of the tag decode shows that the car was meant to have a 8.75 / 2.76:1 anyway . I don't know why there's a different axle under there, especially as I removed a leaf spring a couple of years back , and those U-bolts hadn't been undone in decades. It's a mostly one family-owned car, with no sign of any mods .
If anyone knows about 1970 B-body broadcast sheets, the axle on mine is coded 096 - does that agree with the tag decode ?
Cheers,
Matt
