Hilborn injected 65 Belvedere
- Cannonball
john, do you use fuel pills with this setup, i need some for the amx
- Jon Connolly
- Jon Connolly
Don't know much about Hilborn systems but I do know they use what they call pills to adjust fuel delivery, bit like nitrous jets I think. I wouldn't expect it to be exactly economical, but that sounds crazy, can you not lean it off some?
- Jon Connolly
Yep
How it works is fuel is delivered to the 8 into 1 connector block by the pump at a fixed velocity. You then set the butterfly valves up by adjusting all the linkages so that all the cylinders are doing the same duty. Any unused fuel is then sent back to the tank via a return line with a restrictor in it ( fuel pill ). Hilborn ( as far as I know ?? ) only do a restrictor for petrol and a different one for alcohol. I`m sure there are available some after market different sized restrictors for altitudes / different states of tune.... or you could get into drilling or soldering the orifice yourself.
I was conscious with this not to have too much fuel being delivered and washing down the bores .... this isn`t the case so it`s probably just a case of getting a couple of passes on it and then pull the plugs and recheck the oil has not got any fuel in it. I`m happy that it is there or there abouts but will find out when I take it to Shakey.
Hilborn technical service is about as good as British Gas customer service !
- Jon Connolly
Fuel pill is the brass fitting on the return line on the LEFT. With the butterfly linkage shut most fuel is returned to tank via this line with just enough going to injectors.
As linkage opens more fuel flows to injectors on the RIGHT with fuel pill determining a minimum flow rate to the tank.
I think ?
I think ?
- Jon Connolly
- Jon Connolly
- Jon Connolly
