Fitting a B&M Megashifter
:) Hi I did it to mine with No problem at all the brackets all came off with a little grinder and take it one at a time. Make sure you get all the weld as you may tap the bracket off the floor and take a small bit of the floor with it :thumbright: I painted around mine before I cut them off so if I needed to re-fit I could with no issues. the new fit is straight forward too. follow the Instructions and bish bosh job done :roll: :lol: The bit that did my head in was running the cable past the headers. I used P clips on the bottom of the trans converter cover plate, To hole the cable away from the bottom of the headers. How long is your cable :? as some are to long. Best of luck and keep us posted :lol: :shock: :D
Gringo
Post by Gringo »
Can you take some pictures as you go. It's something I'm going to do soon... :thumbright:
BTW - its a standard kit we have, with the 5' cable supplied.
Cheers
Dave S[/quote]
FIVE FEET OF CABLE is going to be fun to run around the motor and trans and still keep away from the headers :? USE THE P Clips :D and may the force be with you :roll: :D
