Bad Luck for Mopar Racers at Easter Meet
DaveB wrote:I went to York raceway Saturday night,set off at 8pm,35 minutes later,sat on a roundabout with a broken U/J on the motorhome,with trailer & superbird.
Called my old fella,he came out,I pulled off propshaft,left the wife in motorhome whilst I returned home to try fix prop.
Didnt have a U/J,so called a mate,unbelievably,he had one.
Returned to motorhome,refit prop,on my way again,arrived at midnight
First run on Sunday,did burnout,got stopped for leaking oil,just a rocker cover gasket,so fixed it.
Second run,nice wheelie,no drama,9.49 into a head wind,called it a day.
First Qualifier on Monday,dialled 9.45,ran 9.49 still a head wind,jobs a good un.
Second Qualifier,running Good,100ft from traps,oil light comes on at 6500rpm,I kill engine straight away,roll off track
I pull dizzy out,oil pump drive as sheard off,game over,load up,get home.
Today,remove broken oil pump drive with magnet,put priming tool in pump,pump solid,remove pump and strip,find a piece of broken spira-lock in it ,remove nose cone,pull out engine,remove sump,make a list of parts required,and ordered them
No one said"Racin is easy"
9.49 in a bird?....gotta be making 900hp+?, on motor?, stroker?.....sounds interesting.....
Les
Nice one Dave, thats something to see, thought weight had to come into it somewhere......oh and it wouldn't be me if I didn't say there's about 2/10ths in your chassis somewhere, and a bit from your 60ft, if you can find it, mph slightly up cos of it,......hope it fixes ok and not too much $$$$.....8 sec car with a bit more comp in it ......tempting perhaps to put a small 100shot on itDaveB wrote:Dynoed at 857hp,580ci,runs on pump gas,weighs in at 3260lbs with me in it,best ET 9.36@148,best 60ft 1.39.
Thanks for best wishes guys
Les
it used to live round the corner to me owned by a guy called mark ,john done a lot of work on it and then took it on a trade in on his mustang I think ,mark used to come on here as perks ,think he still has his mustang and he also has a fiftys mopar with modern running gearpete walton wrote:Engine damage,,,bits on the outside,, that should be on the inside at the finish line....Shame,, he really looks after that car ...Used to be Websters car at one time i believe...
I've rounded up all the bits Les but the house has taken over lately- lots of extending, knocking walls down etc.
Hopefully I'll get on the motor and get the body painted in the next few weeks but I won't have the funds to race it this year.
No, I'm not done mate... just biding my time
