vibration and trans tailshaft bushing
Ive been tracing some rhythmic vibration for a while. I've ruled out UJs, prop and diff bearings and now looking at where the slip yoke enters the rear of the 727 tailshaft.
Thee is clear up/down movement where the yoke goes into the tailshaft.
It occurred to me that the brass bushing could be worn
http://www.ebay.co.uk/itm/727-A727-Exte ... 0648871032
Has anyone done this job and does anyone have the specialist bushing removal tool that I could borrow?
Demon James
Post by Demon James »
:atthemovies: I shall watch this with intrepidation, Miles.
I too have a similar theory with the Demon. Not loads of movement but I can move the slip yoke up-down-sideways etc and wondered how the shaft is supported internally.
It will be great to see how you get on mate and good luck :thumbright:
terryr
Post by terryr »
Check for cracks in the tailshaft housing too,normally go infront of the mount,I done one on the demon,can be hard to spot when stationary
Any cracking on the tailshaft will start at the speedo drive hole and eventually go all the way around, so that's where you look. Changed loads of tailshaft bushes, you need to remove it from the gearbox and press it out on a hydraulic press. Even with a new bush there is an amount of play so don't expect zero movement.
Thanks all. I'll check at the weekend, but the trans was rebuilt this time last year with no reports or indication of cracking.
There is a tool to do it in situ. Ever come across one Blue?
Also, does anyone know how much play is permitted. Got to get this vibe situation sorted.
This type of tool
http://atoztool.com/2200A.html
I just read that there should only about1/8" play. I have more than that, near 1/4" so I reckon I'll replace the yoke as it has grooves on it.
Not seen that tool before. The bush is thin and can be in there really tight, I have my doubts that tool would work in all instances.
Found the correct Chrysler tool but at $244 plus shipping I'll let it go :?
I'll replace the slip yoke first and then see how it looks
Mick70RR
Post by Mick70RR »
I replaced the tailshaft bushing and there was still plenty of play between the bush and the slip yoke. I didn't have a vibration before or after, it was replaced as a matter of course when I rebuilt the box. I think your vibration is something else.
I did have a nasty vibration once but it turned out to be the rear wheels out of balance.
Ok Mick,that's worth a thought. It has got progressively worse hence my view that something is worn.
I have spare wheels so I'll simply swap them over and see what occurs.
ANTON
Post by ANTON »
Miles you can remove the tail shaft off the gearbox in situ and the replace the bushing and then reinstall the tail shaft.
Remove trans mount, speedo drive and undo the five tail shaft bolts and the release the bearing cir-clip (under the metal plate under the gearbox mount) and pull the tail shaft off.
I've done a few governor weight changes like this.
Call me if you want any gaskets. I might even have a tail shaft bushing.
As Blue says even a new bushing has play.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Thanks Anton, that's helpful.
Before I go any further I'll try different wheels (easy), then I'll pull the prop and give the yoke a thorough inspection before looking at the bushing.
The vibration is rhythmic and typical of Mopar it seems, but I cant live with it so I need to diagnose it.
Anton, don't suppose you have a good yoke available? think mine is the longer version, but I'll report back at the weekend.
its not too bad a job, but I was wary before I did mine
thoughts of smashed bits of ally.
I only needed to do the seal but I wasn't confident at getting it off with the housing on the car so I took the housing off and did both while the box was drained
took off tailshaft housing
prized out seal with an array of vicious looking Paint tin openers (every bad screwdriver and chunks of flat steel that I have)
medium sized hammer to knock its metal rim up helpful
the bush
the case has a slot in it at 4 o'clock or 8 oclock (or it did on mine)
I cut into the bushing with a hacksaw blade along the line of the slot
but that took ages so I concentrated on the open end and that allowed me to ping up the edges of the split to act as a bit of purchase for the next ATTACK
heated the housing and tapped the bushing through with a big hammer and a socket
when I say tapped...it took a long time
if you buy a 727/BorgWarner 4 speed bushing and seal from Australia
you get one with the rubber bellows on the end like the orginal
Rockauto also have these occasionally
otherwise UK Jensen and range rover will do. its just a flat press in spring loaded job (rock auto is cheapest and proper brand-you-know makes are not expensive)
bushing goes in with the gulleys and hole to the bottom
I used a bit of steel plate with a hole in it, a long bit of stud ,a wing niut and a hex nut and a big washer from wickes through the housing and bush then a hole in my black and decker workmate below the main case end of the housing to act as a massive puller to pull in the new bushing
gently tapping it with a BFH would have bruised it some what :)
seal goes on no problem tap it in with a peening hammer or another big socket. I glued it in with hylomar, not sure if you need to but hey it acts as a lube as well, I positioned the vent hole in the bellows upwards. if any oil gets that far I want it lubricating the seal and the yoke not falling immediately onto the garage floor. no idea if that is correct
fill the bellows with grease (leave a hole for the yoke)
800 then 1200 grit wet n dry with brasso will clean up the yoke to a mirror shine in the area where the seal runs, the area where it sat in the bushing is most likely already clean the new seal will run in a different place from the old just because you know it will, on a rusty cruddy bit.
to Bananarama! up use a cotton trainer lace or if you have leather strap or lace use that
wrap round 1 full loop with the ends towards you that holds the wet n dry round the yoke and just pull it back and forth until your arms hurt, vary your position from time to time so you don't make it oval shaped
finish by hand
Bananarama! all down with water to get the abrasives off, and Bananarama! with diesel or wd 40 to stop it rusting during the time it takes for you to be filled with the urge to put it back together again.
when you have the seal and bushing in hand its worth while finding a lid off a deodorant or paint can that fits perfectly within the main inner part of the seal but has a deep enough cup to it to enclose the out put shaft
that way you can use it as a stopper from this point forward and never have to drain the trans if you pull the tail shaft for any prolonged period where you can't leave the car propped up resting practically on its nose.
Dave, as ever, thanks to your mental dedication to us all! No wonder you got an award :occasion1:
I'll go for a new yoke most likely, once I've checked mine properly over the weekend.
ANTON
Post by ANTON »
Hi Miles
Propshaft Services in Feltham can supply a slip yoke if needed. That is where i got mine when my uj let go.
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
