Looking for stock exhaust manifolds, a pair, or just a left side one, to fit a 318cu ins block. left side one has exit pipe to the rear. mine is LHD but i think they are all the same. thanks
STICKY
exhaust manifold"s
Re: exhaust manifold"s
found out a bit more info. Casting number is 2465719, and its the same for 273,318,340 and 360 cu ins engines
ddingley
- aussie pete
Hi, I’ve got some original cast iron ones from 318 Aussie Charger (I believe they are the same) and if your location is correct, you are local!
I’m not sure what you mean about the LH one having the exit to the rear.
The LH one ( on RH drive cars) has the manifold heat crossover valve fitted which puts hot air through the inlet manifold until it gets up to working temperature
