1970s DART
Thomas Butler
1970s DART
Post by Thomas Butler »
Good morning guys today I went a brought myself a nice little dart 360 convection and 727 transmission
In need of a little pick me up so if anyone has any recommendations it would be be greatly appreciated as this is my first classic American mopar .
What should I look for and any suggestions on updating parts
Need to source or install air-con and heating
Sent from my iPhone using Tapatalk
Re: 1970s DART
Very nice and the colour is right and noticeable, enjoy :thumbright:
Re: 1970s DART
Installing aircon is a big job and not cheap. Heating should be a bit easier, it may be your is just disconnected, usually because the heater core leaks inside the car.
There are aftermarket heating and aircon options from Car Builder Solutions or similar, or you can source all the bits second hand from someone who has stripped all the aircon off to go racing.
Main question would be why do you NEED aircon. It could be a world of pain very quickly, but this is just my view.
mygasser
Re: 1970s DART
Post by mygasser »
have a look on the car builder solutions website, they do a few different universal ac/heat systems and all the parts needed for a full install. ok, you'll need to make some mounting brackets to suit but if you're ok with the job off fitting it that won't be too taxing for you. :thumbright:
neil.
https://www.carbuilder.com/
Thomas Butler
Re: 1970s DART
MattH wrote:Installing aircon is a big job and not cheap. Heating should be a bit easier, it may be your is just disconnected, usually because the heater core leaks inside the car.
Thanks MattH
The car is an original AC car according to the build sheet so hopefully not to complicated .
On the build sheet green is not the original colour but it’s (BL1 beige) the car has been restored in the USA apparently 20+ years ago so it now runs a 360ci and a 727 transmission and a 8 3/4 axle condition is good needs a little TLC (paint work suspension /shocks but the Frame and rales are in great condition .
Thomas Butler
Re: 1970s DART
mygasser wrote:have a look on the car builder solutions website, they do a few different universal ac/heat systems and all the parts needed for a full install. ok, you'll need to make some mounting brackets to suit but if you're ok with the job off fitting it that won't be too taxing for you. :thumbright:
neil.
Thanks neil any other websites you know off would be helpful like I said my first American car project
Also want to see where I can get nice set of brakes etc fort I’d get chassis done before pushing for horse power
mygasser
Re: 1970s DART
Post by mygasser »
here in the uk rally design are the agents for wilwood brakes. they do very comprehensive brake kits. they include ally hubs, bearings, discs, carrier bells and all fixtures, fasteners and shims. i've fitted a few to various 'yanks' and the instructions are idiot proof (just right for the US market, lol). :thumbright:
neil.
https://www.rallydesign.co.uk/index.php ... a8h6mfgll1
Thomas Butler
Re: 1970s DART
mygasser wrote:here in the uk rally design are the agents for wilwood brakes. they do very comprehensive brake kits. they include ally hubs, bearings, discs, carrier bells and all fixtures, fasteners and shims. i've fitted a few to various 'yanks' and the instructions are idiot proof (just right for the US market, lol). :thumbright:
neil.
Thanks neil I’ll get a look
Thomas Butler
1970s DART
Hi all just looking for a bit of advice if it’s the right thing to do
Is it best to bolt in a full steering and suspension assembly to my newly acquired dart as power steering system has seen better days .
I also looking to give myself a bit more room in the rear arches so I can fit a bit more rubber on the back .
See there’s a kit I can buy for not to much money it’s a bit of fabrication involved ( more than comfortable with that )
Or am I best just to keep it as is ???
But colour needs to change Image
Engine needs a little tidy up paint etc Image
Re: 1970s DART
You probably do not want to hear this, but the first thing I do when I get a Mopar is to take the Power Steering off; in most scenario's you just do not need it.
A good second hand manual steering box and a column mod and you are good to go! All that weight off the front end too!
My wife happily drives our 440 powered 'Cuda with manual steering!
