bolt sizes
- Trigger_Andy
bolt sizes
hi all,
does anyone know of the top of there head what size of bolts holds the carb down on a 4 bbl edelbrock manifold and also the bolt that holds down the air filter on a holley carb?
cheers,andy
cheers,andy
- Trigger_Andy
- Trigger_Andy
Bolts for carb to manifold are 5/16 unc ( standard forr 99% of us cars) the air filter stud is either 1/4 unc or 5/16 unc unless you have an early dominator ( 5/16 bsw) if you need studs let me know i have some , studs are better than bolts if you intend to keep taking the carb off . i will have some at the nats if you need them.
- Trigger_Andy
- Trigger_Andy
