Bottom end blues
Alex
Post by Alex »
Slip some bearings in there and see how it goes, kill or cure unless you want to go the whole way, I have replaced bearings in motors worse than you describe and they have been just fine.
I would agree with Alex and slip some bearings in there and I would suggest using Clevite 77 as they have a a tri-metal contruction with a babbit coating (I think).
Anyway, technical nonsense aside, these bearings can handle worn journals and a bit of scoring, so as they say in legal circles...whack 'em in, give it a spoodle and Robert is very much your mother's brother! :wink:
From the markings you've got there Steve, my best guess is thay are Michigan 77 bearings and they are 10 thou oversize.
Your best route is to measure those journals though...if you were still living down the road, I'd lend you a vernier or a mike!
Is mike good with engines then? :D
bottom end
Steve, I had a similar problem with my Chevy last year. just fitted new bearings and took a chance on the crank (which looked fine), got lucky as engine ran silently and oil pressure returned. could be worth a shot just for the summer.
ps thanks for the diff. It fits!!
Alex
Post by Alex »
Be carefull, the number you are pointing out looks like a date code....
Alex
Post by Alex »
The lack of obvious markings leads me to belive they are standard.
Alex
Post by Alex »
Full groove bearings will be fine mate..
Alex
Post by Alex »
Well done sir ! :occasion1:
