Headlight upgrade
Headlight upgrade
Some good info here on headlight upgrades, it's nice to see where you are going!
http://www.danielsternlighting.com/tech ... elays.html
Guest
Post by Guest »
Nice one Blue - will bookmark that page when I come to re-wire the 'money pit'
Cheers :D
i got a harness with it all in pretty cheap from www.directauto.com only word of warning is that the harness will not cope with four main beams illuminated at the same time! I disconnected my inner main beam and it is all fine and dandy now. If i had thought in advance I would have pulled the clip out of the outer main beam and then it would look like a normal car!!!
Ah! Is that where Dan Stern is these days? He used to be a regular on the old RAMM mailing list.
