360 engines
Dougie, this is quite useful:
http://www.mopar1.us/dyno.html
I built a 360 last year and it will transform your car. I kept mine fairly low comp and used Comp cams XE262HE grind. This produced a very tractable engine that can be cruised or thrashed. if i did it againi would go for higher comp Keith black pistons (about£250 i think) and a 268 cam or one of the Hughes engines cams.
- Trigger_Andy
There are plenty of diffs available for the Borg Warners both LSD and GAY (open), since the company that made them originally still offers them. However they are all on the other side of the planet and postage ain't cheap.
Although the 8 3/4 requires a bit of tinkering to fit in the Borgy's place, it is much stronger and pumpkins are more available over here.
Hi Dougie
I'm green here, only just joined, but I hope this proves useful.
I recently got a book from the states "How to hot rod smallblock mopar engines". Its absolutely fantastic and gives you loads of detailed technical (boring, stroking, decking - The lot !) and background info specific to all A & LA(Lightweight) series smallblocks. Its also great because it lets u know whats compatible between the different engines and whats not.
Did u know you can get a 4 inch crank for a 360cid off the shelf (States job), and make it into 402 cubes without boring ?
You can get it from "Year one" in the states or better still try "Real Steel" in the UK - They deffo have it.
Get it - Its goooood
CP! 8 3/4 has a central pumpkin which is just unbolted after the halfshafts are removed. A banjo style axle. The 7 1/4, 8 1/4 and 9 1/4(Dana) have the gears in the axle housing so you have to "spread" it to get the gears out. Is this what you are getting at?
All the info is here;
http://www.autohobbydigest.com/a-rearend.html
