ignition timing some odd readings - sorted
having never taken a dizzy apart before I might need it
didn’t need the limiter plate after all
the dizzy has already got an adjustable mechanism
live and learn …
live and learn …
- DSC_1333.JPG (87.61 KiB) Viewed 777 times
I measure the slots where the advance tabs sit at 6.5mm initially, that was giving me 21deg of advance, wanted 14deg, worked out the gap needed to be 4.3mm, set it, tried it …
rpm … -> … advance
850 … -> … 20
1500 … -> … 23
2000 … -> … 32
2500 … -> … 32
3000 … -> … 32
3500 … -> … 32
not bad for first attempt
do you think I need to fit a stronger spring??
I took the car for a run, seemed well happy with the new settings, no detonation what-so-ever
I am going to open up the gap a touch to get the desired 34deg
rpm … -> … advance
850 … -> … 20
1500 … -> … 23
2000 … -> … 32
2500 … -> … 32
3000 … -> … 32
3500 … -> … 32
cheers Steve/Dave
righto sorted, initial 20deg, total 34deg
everything’s peachy so going to leave it like that for now
thanks again
will do Dave
will do Dave
