Mega block
mopar_mark wrote: gotta to love a dremmel moment ;)
170* is excellent, mine still makes me a bit nervous, if too much traffic about.
Tis the simple things in life Mark , could'nt be arsed to wait for the smaller cams from Summit , so thought i'd make me own , must of got lucky as the motor responds instantly when you hit the gas pedle. ;)
NaughtyAlan
Post by NaughtyAlan »
Just like it should Adam with no hesitation. Does the back end try and over take you as well :thumbright:
NaughtyAlan wrote:Just like it should Adam with no hesitation. Does the back end try and over take you as well :thumbright:
Don't matter how much torque a motors got , if the fuel ain't there it ain't goin nowhere.
Yep can see me bumble stripe comin round when i floor it. :D
You gonna give me you're approval tommorow Al. ;)
NaughtyAlan
[quote=
You gonna give me you're approval tommorow Al. ;)[/quote]
Better put a brick under the peddle and keep me of the Stella's then ;)
NaughtyAlan wrote:[quote=
Better put a brick under the peddle and keep me of the Stella's then ;)[/quote]
:D ..........or give the Stellas to No Neck. :lol: :lol: :lol:
Rogue Trooper
Post by Rogue Trooper »
8-) well done brutus, how long before you take the car to a track?
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
As soon as i can get some more $$$$$$$$$ together , has cleared me out this motor. :roll:
Nice one Adam, that motor never got hot at all, you couldburn out at 170 and it'd go thru the traps at 180-185 where the 493 would go thru at 200+ :thumbright:
Thanks Mark , no probs with temp so far , took it out again today with Naughty Al , slipping on the vertor a bit (3200 stall)), probably due to more torque compared to the other motor (440) , seems to tame it a bit for street driving , gearbox temp is fine so no prob with slippage , just wondering what it will be like on the track , might get a bit of blow through on the sniff , will wait & see.
Adam this car has the same set up perhaps you can try this out side the Ace tonight? :D
pic of engine from the ace last night
muzzydave wrote:pic of engine from the ace last night
Looks very Yummy, as they used to say 8-)
Sure looks busy in there! Proper motor!
How clean is your - engine bay?
Adam is that a speck of dirt on the top of the radiator? :D
Re: How clean is your - engine bay?
Knightcharger wrote:Adam is that a speck of dirt on the top of the radiator? :D
As you know , tis where i rest me fag between puffs. :help:
:D
