Not sure what your expecting, but only a small amount of video, as was more interested in what was happening, as opposed to filming what was happeningGuy wrote:![]()
I can't wait for the video Mark, it sounds like you had a great day
Mopar_Mark - 71 Cuda
- mopar_mark
Excellent
Fantastic stuff, can't wait to see it all sorted!
"850hp at the rear wheels" - so about 1000 at the flywheel
- mopar_mark
Not sure how you convert or what equates to whatMrNorm wrote:Excellent![]()
"850hp at the rear wheels" - so about 1000 at the flywheel![]()
Close enough, there is no surefire conversion but some reckon 20-25% loss for an auto. Some reckon a fixed amount. (I suspect a mixture).
1100 @ flywheel and 850 @ wheels doesn't sound implausible. Forget which trans you have?
But I'd have thought 850 was towards the lower end!
- mopar_mark
Here's a small video clip. As I said before, I was more interested in the car, than videoing, so quality is a bit naff.
Could of done with someone to do the filming really or a tripod, so I could of just left it recording
- Dave-R
The losses of a transmission are fixed. It takes a given amount of HP to drive the trans. Something around 75hp for a stock type 727.MrNorm wrote:Close enough, there is no surefire conversion but some reckon 20-25% loss for an auto. Some reckon a fixed amount. (I suspect a mixture).
The converter is something else again though. That is all down to how much slippage you get in it. The more torque you make the more it will slip.
- mopar_mark
Fitted a new electric fan this week, as old electric fan was struggling when in traffic. New fan is rated at 3,300CFM & also has a shroud, so hoping it will do the job.
What should of been a simple couple of hours job, turned into major mod. Moved the rad back 3", as fan was too close to bottom hose, forcing hose into blower belt.
Had to fabricate new mounts, but still wanted to be able to remove the front without touching the rad. Initially, was going to use a cross brace/member (thanks for your help Jerry) but ended binning that
& eventually thought of a much simpler mount
With the rad being moved 3", was unable to put on the bottom hose, so had to cut bottom neck off the rad & reweld neck at 45 Degrees. Had to remove the bottom hose joint & recrimp to suit the 45 degree neck. Also had to extend one of the top hoses. Hoses were a pain, as fiddly cutting off the crimped joints & not damaging the hose.
Pleased with how it turned out
just need to fabricate a couple of stays tomorrow, no big deal, just a couple of saddle clamps, bit of tubing & couple of rod ends for adjustability.
Had to weld a ally pad on the rad, so I can mount temp sender. So need to buy a 6mm compression olive/fitting tomorrow,to hold the sender. But wont drill & tap pad, till I have got the fittings. Most likely end up down the boat shop, going through all their fitting
If you have a boat shop nearby, I highly recommend, as they seem to have an abundance of various fittings in Aluminium & Stainless. As opposed to regular brass fittings.
As usual, big thanks to my mate Paul, for welding & helping me from further self mutilation... In the last week, I have sliced a slither off the top of my thumb, gounged my finger & today, slipped with the drill today & drilled through my thumbnail
I hope it works after all this
- mopar_mark
What of my injuries ? Sorry, it didn't occur to me to take any photos, but will bear it in mind for next time.Philth wrote:"In the last week, I have sliced a slither off the top of my thumb, gounged my finger & today, slipped with the drill today & drilled through my thumbnail"
I wasn't anywhere near, I swear.
Any pic's, Mark?
If you meant any Pics of the Cuda, see Events - KK's for photos from on Sunday ( GTXJim, bbb:thumbright:) or Muscle Car Lounge -Some old Green Cuda video from Derek
- mopar_mark
