a bit of this and a bit of that
mygasser
Re: a bit of this and a bit of that
Post by mygasser »
nothing worthy of pics, just more running of wires etc. gauges are back in the dash, the oil pressure gauge pipe is rerouted and now goes through a grommet at the bulkhead. the engine even turns over on the key :thumbright: . we even added washers and a locknut to the throttle cable where it goes through the bulkhead, the whole cable was flopping back and forth in the hole like a pr*ck in a shirt sleeve, lol.
neil.
mygasser
Post by mygasser »
it seems i've located a tunnel ram for my nash. it's had the top altered for (i think enderle?) injection so i'll need to do something with that but it's not the end of the world.
neil.
tunnel ram 351c.jpg (93.53 KiB) Viewed 18391 times
mygasser
Post by mygasser »
i just ordered a quick release steering wheel boss and (just in case) a 3 hole to 6 hole adapter as i don't have a steering wheel yet. both are for my nash.
neil.
mygasser
Post by mygasser »
back to the '32 rewire. we now have all the lights, wipers and rad' fan working. dash wiring is ready to be plugged into the dash 'sub loom'. if we get a good crack at it tomorrow/wednesday we'll have it on the floor and running ready for the swapmeet. cushty :thumbright:
neil.
mygasser
Post by mygasser »
bit more done today, the dash is hanging almost in position and everything's connected and works. we'll get the dash bolted in and the new wiring tied and sleeved neatly tomorrow.
my mate who's car it is arrived in his new toy after lunch, a steel model A coupe fenderless hot rod. it has a fully detailed chassis with a 350/350 up front.
we have to collect a 2.0 (2.1 i'm told) pinto and auto box with lokar shifter by saturday so it can go for a ride to the swapmeet sunday before being dropped off at john gumble's shop ready to go in his new '39 willys. it's all go, lol.
neil.
mygasser
Post by mygasser »
in between 'jobs' i've been watching episodes of 'full custom garage'..... again. bad idea really, it's making me think of what we can do to my mk2 zodiac once it's here #-o
neil.
mygasser
Post by mygasser »
oh and i've bought another set of slot mags :D 10 x 15's with 275/60's and 4.5 x 15's with 165's. they may go on the zodiac..... not sure yet.
neil.
mygasser
Post by mygasser »
dash is back in, wiring neatened and secured, drivers floor in, tunnel and bellhousing cover in, seat in, fuel line at carb fitted, tranny cooler lines fittes and connected and cooling hoses fitted. my mate's popping round with petrol and tranny fluid friday so we can fire it up, it's not run properly since he fitted a good rover v8 he had replacing the old knackered one. tomorrow we're collecting the pinto and box so won't touch the 32.
neil.
mygasser
Post by mygasser »
paid the customs fees today so my jay brown intake adapter should be delivered soon. i'll collect my 351 cleveland tunnel ram at the swapmeet sunday, that'll bolt to the above adapter. just need to see what carb's are there sunday and if not i'll buy a new pair of chedelbrock (chinese edelbrock, lol) 500's.
neil.
mygasser
Post by mygasser »
the 32 was picked up this morning and he tinkered with it and got it running today for a video. it just needs 'going through' now by the new owner but he's pricing it accordingly. the engine/box came from a consul he broke up that ran well but was rotten, it just hasn't run (til today) since being in the 32. all the electrics work now it's rewired and the brakes work good, even the handbrake is good.
in other news the inlet adapter for my fe engine arrived today, woohoo!!
neil.
mygasser
Post by mygasser »
ok, call me a tart/poser but i just ordered 2x 3" electric exhaust cutouts for my nash. i say 2x not a pair as 1 was on offer so £10 less than everyone else so i bought that and a 2nd from elsewhere.
neil.
mygasser
Post by mygasser »
hopefully the 360 engine i have will fire up and run well enough to go in my nash while i build a 390 for it. i've got the inlet adapter and tunnel ram now and i'm looking into a retro fit roller cam swap. the cam and lifters will add up to about £800 which sounds a lot but it'll eliminate the issues with flat tappet cams/lifters. we'll see.....
neil.
mygasser
Post by mygasser »
so i've ordered more bits and bobs for my nash and it's started to arrive. a lump of 8mm aluminium plate to unmodify the top of the tunnel ram, a pair of 1/2" phenolic spacers with studs to a) insulate the carbs and b) keep the carb linkages off of the above plate. also countersunk m6 allen bolts and nylocs to hold the plate to the top of the tunnel ram, a valve spring installed height checker, a new pair of butch crocodile clips for my big boy's snap on battery charger/starter and both of the electric 3" exhaust cutouts. oh and the very pretty steering wheel too :thumbright:
we got the plate cut to size, the holes cut out to the open spacer's size and the stud holes drilled ready to tap. then it was full stop as we couldn't find a 5/16 unc tap.... bu66er, best order a couple then. #-o
neil.
mygasser
Post by mygasser »
the thread taps arrived today, too late to get out and cut the threads though. we'll get that done tomorrow along with some countersunk holes in the plate and through the top of the tunnel ram so we can attach it.
neil.
edit, i also ordered a nice shiny centre/horn push for my nice shiny steering wheel. :thumbright:
mygasser
Post by mygasser »
i took delivery of a 4" length of 4" internal diameter stainless tube today. i intend to make an adjustable tapered piston ring compressor to make future engine builds a little easier.
neil.
