Mathematical Question
One for all you Vordermans! What sort of difference to a Compression Ratio if the compressed thickness of the head gasket is 5 thou thinner. (3.91" bore)
I've looked closely at the relationship between the thickness of the head gasket in direct comparison to the effect that has on compression ratio and performed an experiment to make a calculation on the possible increase in efficiency and therefore, performance.
By taking a close look at the configuration of heterodyne interferometry with the fiberoptic sensor. A frequency stabilized He-Ne laser, with a wavelength λ of 632.8 nm and an output power of 1 mW, provides a linear polarized beam for the measurements. The AOM system for heterodyne interferometry produces two beams. In this experiment, the frequency of the first beam is shifted by 80.100MHz, and that of the second by 80.125 MHz.
The stability of our AOM is within 0.02ppm.These beams meet at the polarized beam splitter and create a beat frequency of 25.0 kHz. After the polarized beam splitter, the beam is split into two by the half mirror.
One beam is detected by a photo-transistor as a reference signal; the other is used for modified Michelson interferometry. The reference signal beam passes outside the combustion chamber and is reflected by a mirror.
The beam used for modified Michelson interferometry passes through the test section, is reflected by a mirror, and then passes back through the test section again.
The result was a drastically improved flame front in relationship to the .00355479 % increase in compression ratio, by using the thinner gasket on the small black Mopar engine.
Since I am still officially a student engineer this is free
Assuming:
- 3.91" Bore
- 3.31" Stroke
- 0.039" Compressed gasket height
- 4.180" Gasket bore
- 64.5cc Chamber
Your compression ratio will be 9.97:1
If the gasket is 5 thou thinner (compressed) then your compression ratio will be 10.1:1.
I would be more worried about the crevice between the head and deck created by the oversized bore of the gasket though. That is a nice area for burnt gases to collect and then spoil the fresh mixture coming in.
Incidentally if you could match a gasket of exactly 3.91" bore then your compression would be 10.1 at the standard height and go up to 10.2 for the 5 thou thinner gasket.
Assuming:
- 3.91" Bore
- 3.31" Stroke
- 64.5cc Chamber
